408
OxygenOS 11 for the OnePlus 6 and OnePlus 6T
  1. rHITkM.
    Ice Cream Sandwich Sep 13, 2021
    rHITkM. , Sep 13, 2021 :
    over exaggeration or Paid review !🤨
    Gery S., Iheb87 and Auristic like this.
  2. Max.Mar
    Jelly Bean Sep 13, 2021
    Max.Mar , Sep 13, 2021 :
    13 Hours..OMG!! Could you please share screen shots of your battery usage & SOT.
    Either I am not aware of something or you don't know anything.
  3. A1550387522048
    Honeycomb Sep 13, 2021
    A1550387522048 , via OnePlus 6 , Sep 13, 2021 :
    Total with around 3 hrs of screen time charge drains in 38 hrs. But if you use only screen except the games only videos, movies etc. And my device is in its 3.5 yes old. However when you use mix with surfing on internet, movies and others takes only 15 hrs total.. I charge every day up 80%.
    Of course I believe you are also playing the games, listening music and surfing therefore you have right the drain will be faster than me.
  4. mohd_areeb
    mohd_areeb , via OnePlus 6 , Sep 13, 2021 :
    I have to reset the data of Google Maps to use it properly, after i use the app and close it, reopening the apps, compass doesn't work at all.
    How much i callibrate it it stays the same, resetting yhe data only helps.
    Dp anyone faced or facing the same issue?
    Let me know of you've any solution.
  5. Andrei Agulescu
    Eclair Sep 13, 2021
    Andrei Agulescu , Sep 13, 2021 :
    This update definitely feels rushed. I installed the stable Oxygen OS 11 (based on Android 11) update and after using it for a few weeks, I could definitely tell that it had issues.
    The camera is unusable at times. When opening the app, it never goes past a black screen, even if I close the app and open it again. To make it work, I need to clear the app cache and retry. There are also issues with other apps that use the camera. For example, using Google Translate to scan some text with the camera, will result in blurry images. In fact, there is an issue with the camera's focus in almost every 3rd party app.
    Speaking about the camera, very often when opening the app, the screen calibration would change -- it would switch to some sort of "Vibrant mode", with very saturated colors. When exiting the camera app, it would revert back to whatever mode it was in previously but a lot of times it would be stuck in that vibrant mode and I had to restart the phone to reset the display. Changing the screen calibration in the settings app would have no effect.
    Auto-rotation is very unreliable, sometimes it doesn't work at all even if I disable and then re-enable it. Never had this issue in Android 10 / oxygen OS 10.
    The screen brightness updates very slowly, it's annoying.
    Overall, a lot of apps glitch during use, there also seems to be a more aggressive RAM management that kicks processes out of memory more often. I noticed more app reloads when resuming.
    I've even had issues with the fingerprint reader where sometimes it just randomly wouldn't work and I had to restart the device.
    I did do a factory reset and a clean install of Oxygen OS 11 but I had the same issues. In the end, I reverted back to Oxygen OS 10 / android 10 because there were too many issues with this update. Hope they get sorted because it's a mess.
  6. Danygarces
    Cupcake Sep 14, 2021
  7. rHITkM.
    Ice Cream Sandwich Sep 14, 2021
    rHITkM. , Sep 14, 2021 :
    Keep waiting or use oxygen updater as mentioned numerous times in this thread.
    Auristic, Zarc and D.Sai Suhail Baba like this.
  8. priyank pande
    priyank pande , Sep 14, 2021 :
    Hi Abdul
    I have still not received the oxygen os11 update in my OnePlus6 yet
    Can you confirm when can I get it ?
  9. ItsRavi25
    Jelly Bean Sep 14, 2021
    ItsRavi25 , via OnePlus 6T , Sep 14, 2021 :
    No one will answer....
    Read the post above your post.
    Auristic and rHITkM. like this.
  10. stupidaakash , via OnePlus 6 Silk White , Sep 14, 2021 :
    I think the staged rollout has been paused due to many bugs reported by users as it is more than a month many of us didn't receive the update . usually we start receiving updates within 15-25 days of staged rollout (as observed in past).
    said:
    Similar happened in past while transitioning to Android 10 , many of didn't receive oxygen os 10 we directly got 10.1
    Let's hope whatever they send us as an update does have major bugs fixed and can be used as a daily driver
  11. jo_wi
    Froyo Sep 14, 2021
    jo_wi , Sep 14, 2021 :
    Here:
    https://forums.oneplus.com/threads/oneplus-software-maintenance-schedule.862347/
    In their update to the schedule, to be found here
    https://forums.oneplus.com/threads/...se-and-software-maintenance-schedule.1462181/
    OnePlus haven't specified another schedule for sec. updates.
    The 6T is on July's security updates while the updates for September have been out from Google since the beginning of September. So OnePlus missed their promised schedule once again, like almost every time.
    And by the way: bi-monthly security updates are basically worthless, because it leaves devices vulnerable to the bugs fixed in the "other month" updates from Google.
    The funny thing is that some hobbyists over at Lineage manage to crank out the updates on time and every month for a lot more devices than OnePlus ever produced. This includes most of the OnePlus devices of the past.
    K1577555224305 and Ronesso17 like this.
  12. FaleshC
    KitKat Sep 14, 2021
    FaleshC , Sep 14, 2021 :
    some hobbyist at lineage and many more custom roms are able to release security patches sooner because their roms don't have to be submitted for CTS certification which may take weeks before OnePlus can release a stable update.
    the 6- series are towards EOL, I wouldn't expect quicker updates.
    LegolasX and Auristic like this.
  13. Abhishek.001
    Honeycomb Sep 14, 2021
    K1577555224305 likes this.
  14. C1607240911900
    C1607240911900 , Sep 14, 2021 :
    I haven't received Android 11 update and it's been over a month now
    I have OnePlus 6T
    How can I get it?
  15. Royal_RJ
  16. Auristic
    Lollipop Sep 14, 2021
    rHITkM. and ItsRavi25 like this.
  17. VDS1997
    Donut Sep 14, 2021
    VDS1997 , Sep 14, 2021 :
    Exactly!!
    Royal_RJ and W1536531382920 like this.
  18. siddharth740
    Gingerbread Sep 14, 2021
    siddharth740 , via OnePlus 6 , Sep 14, 2021 :
    Right i am also checking Daily but don't know when we will receive the update.
    Royal_RJ likes this.
  19. chrisjgill75
    Froyo Sep 14, 2021
    chrisjgill75 , via OnePlus 6 , Sep 14, 2021 :
    I wish I got anywhere near that. Given the age on my phone and it's battery I'm lucky with more then 3 or 4 hours
    Max.Mar likes this.
