408
OxygenOS 11 for the OnePlus 6 and OnePlus 6T
  1. G1549309754359 likes this.
  2. Auristic
    Lollipop Sep 16, 2021
  3. vasuhitter
    Cupcake Sep 16, 2021
  4. rhyd1am
    KitKat Community Expert Sep 16, 2021
    rhyd1am , Sep 16, 2021 :
    The rollout has nothing to do with which device in the series you have (or location). Oneplus rollout updates in a staged way and it can take a while to reach all devices.
    If you want you can download the correct file for your device and install it manually via local upgrade, any time you wish 🙂
  5. Desai_Jay
    Gingerbread Sep 16, 2021
  6. Phanilkumar
    Gingerbread Sep 17, 2021
  7. Suraj.kashyap
    Froyo Sep 17, 2021
    Suraj.kashyap , Sep 17, 2021 :
    Wow! Well said! Every point Is true. I am using OnePlus phones from 5 years and can say that yes, a lot has changed in OnePlus. It is not at all the same brand it was.
  8. Venkatesh_K
    Cupcake Sep 17, 2021
  9. P1534727797666
    P1534727797666 , via OnePlus 6 , Sep 17, 2021 :
    Network Problem.
    Suddenly network drops "No service" / "No SIM" and restarts suddenly....Plz help...missed many important calls
    any rollback option or is there bug fix coming?
    and after update I am noticing GPS is taking a lot of time pin point location...dont know if it is due to the network problem!!!
    Any help is appreciated.
  10. K1535125990312 Charliexop
    K1535125990312 Charliexop , Sep 17, 2021 :
    U probably didnt understand...I didnt say u shouldnt instal apps,i said the new update must be clean installed,that means - factory reset your phone BEFORE the update.When u perform factory reset u will make it just as it was when u bought it( with no installed apps,games,etc) and it will fully clean your phone ( even so called tails from previously installed apps from Store) .Thats clean instalation of new software.When u finish all this- ofcourse that u can instal whatever u want from Store..
    And yes,i also had all those platforms ( and some more)..Bada ( Samsung platform) was good,much better than Samsung androids( laggy and slowing down, plus other issues,bad optimisations).
    Hope u undertand now what i meant.So,in a simple way- factory reset BEFORE the update- do not connect to Play Store after factory reset ( just wait for Store and Services to be update automaticly- when these two are updated,turn off your phone for a couple of minutes and tturn it on again)- and then instal new update.When u finish this,u can instal what u want.This is my experience amd in never failed.
    If we just take a look only at my OP phones ( i have 8T and 6)- well,there have been so many complains with previous updates with these two models,i didnt have a single issue with none of them,in fact it turned out that something was always bettter after updates ( also with my other phones).
  11. HardikMeghaz
    HardikMeghaz , via OnePlus 6T , Sep 17, 2021 :
    Hey!
    I have enabled battery optimization feature on for certain apps and restrict them running in background in Android 11. Whenever i remove that apps from recent list, they still don't force stop automatically and consume some power and RAM. Due to this my idle RAM usage is around 60% of total RAM in Android 11. While in Android 10, RAM usage was around 40% of total RAM.
    Kindly make battery optimization more aggressive don't allow optimised apps to run in background.
    Hope you do some needful.
    K1577555224305 likes this.
  12. Gery S.
    Eclair Sep 17, 2021
    Gery S. , via OnePlus 6 , Sep 17, 2021 :
    Battery life is just garbage! Never had such a shitty battery life bevore! Oneplus, this was a crappy update! 👎
    And ******* it, fix the ******* gmail notifications!
    And consider separate volume for ringtone and notifications, it's ridiculous!!!
  13. K1577555224305
    Ice Cream Sandwich Sep 17, 2021
    K1577555224305 , Sep 17, 2021 :
    Yes these are the most common and irritating issue encountered by most.
  14. K1577555224305
    Yes, it will remain as such. Unless the plus releases any new update
  15. GaneshKunte
    Honeycomb Sep 17, 2021
    GaneshKunte , Sep 17, 2021 :
    I don't mind next update is on time or late. But let's fix all the issues and bugs make sure we have very very stable update next.
  16. __Arun__kumar__
    Eclair Sep 17, 2021
  17. Suraj.kashyap
    Froyo Sep 17, 2021
    Well, I'd say you are a lucky one. I never did any factory reset before or after a major update and never faced issues. However, things were different with A11 update on my 6T. Lags and glitches were impacting my work a lot which forced me to downgrade to A10. Software updates are made in a way that an user don't have to go through hassle of factory reset. In today's time backups are in GBs and takes a really long time to restore everything. Factory reset just to get a smooth experience for a software update is not a solution at all and will never be.
  18. Suraj.kashyap
    Froyo Sep 17, 2021
    That's a known issue and I assume OP devs would be working on a solution.
  19. MagnusFogelberg
    MagnusFogelberg , Sep 17, 2021 :
    Immediately after the last update, I noticed a significantly worse battery life despite the new battery. The screen on time was only around 4 -5 hours and the phone got hot. Yesterday I did a reset and new installation but kept my files on the device. I installed apps and app data manually and not from the backup. I only made manual backups on some app data that are complicated to configure from scratch. The phone now stays cool and the screen on time is between 8 and 9 hours. What a huge difference!!
    Dhanapal_477 and Tornikeavia like this.
  20. osmanhussain
