408
OxygenOS 11 for the OnePlus 6 and OnePlus 6T
  1. Rahul_Malik_000
    Cupcake Oct 16, 2021
    Rahul_Malik_000 , Oct 16, 2021 :
    Issues with update on Oneplus 6 OS11.1.1.1
    1. I uses internet on SIM-1 and send SMS via SIM-2.
    Whenever send SMS via SIM-2, 4G internet stops on SIM-1, then SMS is sent, then 4G is resumed.
    It is stopping internet on SIM-1 then sending SMS via SIM-2. Due to this issue I am unable to register on any UPI application because my registered number is SIM-2 and internet works on SIM-1.
    Whenever SMS is sent via SIM-2, mobile stops 4G on SIM-1, then UPI app shows unable to verify mobile number because of interruption of this internet.
    2. Notification Tone not ringing whenever any message comes. Not ringing in SMS/ Telegram/Whatsapp messages.
    3. E-mail notification not showing. Every time I have to open the Gmail app.
    Sometimes even Whatsapp message notifications are not shown.
    4. Screen is active even when it is locked. When I double tap on the screen it wakes up. How do I turn this off?
  2. W1634495313895
    Cupcake Oct 17, 2021
    W1634495313895 , Oct 17, 2021 :
    How can i degrade to os 10.?? OS11 is shit. Many bugs. No notifications from Gmail. The phone is slow.
    Oneplus i was disappointed.
  3. K1577555224305
    Honeycomb Oct 17, 2021
    K1577555224305 , Oct 17, 2021 :
    Take an extensive backup of current OS
    try oneplus switch also.
    After backup -
    Install an app keepdata
    Run keepdata.
    Search for A10 downgrade rom from the A11beta 1 thread.
    Do as instructed.
    Yes A11 is as you say it is.. these are all known issues.
  4. Gloffo
    Cupcake Oct 19, 2021
    Gloffo , Oct 19, 2021 :
    I have exactly the same problem on my OP6. After OOS11, i lose internet connection on my home wifi (Deco mesh) whenever the Phone switches between nodes. It always worked before, and all other devices we have works. It is very annoying, because you don't always notice that it happens until maybe an hour later, then you have to turn off and on your wifi, and all of a sudden all my missed whatsapp-messages rolls in. As it is now, the phone is practically unusable at home, if I don't turn off wifi entirely, which isn't exactly feasible.
    I have tried clearing my cache, I have reset all connections, I have turned in developer mode and fiddled with the network settings, and also changed to a fixed ip. Nothing works.
    SGLorenzana likes this.
  5. BrenTeck
    Cupcake Oct 20, 2021
    BrenTeck , Oct 20, 2021 :
    WiFi is now very unstable, locking up all the time when trying to turn WiFi off and on.
    Trying to turn on Flight mode just locks up the phone completely have to reboot by holding down the power button.
    Wishing I did not update. 😟 First time OnePlus did an update that made me want to ditch OnePlus. This must be fixed with an update before EOL. Have not tried a factory reset yet and don't really want to.
    Video of the fault
    I hope we can get to the bottom of this and get it fixed.
  6. Tab_iill
    Cupcake Oct 21, 2021
  7. mightymikee
    Cupcake Oct 22, 2021
    mightymikee , Oct 22, 2021 :
    I upgraded my one plus 6 and now my phone runs like crap. Slow between apps and Kakaotalk types in slowmo. Keyboard does not pop up on occasions on different apps, camera takes forever to load. Battery does not last as long.
    Phone used to feel rock solid before but now I feel like I have throttled iPhone with outdated iOS.
    I was getting ready to upgrade into another OnePlus device but I am seriously reconsidering into another brand because of how horrendous this upgrade is.
    Seems like OnePlus seriously have lost its core and original philosophy.
    B1635096173504, relu1989 and BrenTeck like this.
  8. K1577555224305
    Honeycomb Oct 22, 2021
    K1577555224305 , Oct 22, 2021 :
    Can you run an app called CPU Throttling Test.
    Please post the results after that.:)
  9. Kai38
    Kai38 , Oct 22, 2021 :
    Hallo,
    seit dem Update auf 11.1.1.1 funktioniert mein WLAN nicht mehr, mein One6 blockiert auch meine Telefonkarte. Ich muss das Handy neu starten damit es wieder funktioniert ! Nach paar Stunden/Minuten wieder das gleiche Problem !!!
    Kann man wieder auf das alte System zurück oder was ist die Lösung für diese Probleme?
    Gibt es eine Anleitung für ein Rollback zu Ver10 ???
    Bitte um schnelle Lösung bzw. Hilfestellung!
    Danke
  10. rhyd1am
    KitKat Community Expert Oct 22, 2021
    rhyd1am , Oct 22, 2021 :
    Hi, all information regarding rollback can be found in the following thread.
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    Although, since a rollback will involve wiping your device, it might be worth backing up your device and trying a factory reset first 🙂
  11. K1577555224305
    Erste,
    Ich würde vorschlagen, die Netzwerk-einstellungen, über die Option zum Sichern und Zurücksetzen zurückzusetzen. Sehen Sie bitte, ob es helfen dir kann. 🙂
    Nicht Alles zurück setzen.
  12. relu1989
    Cupcake Oct 24, 2021
  13. K1577555224305
    Honeycomb Oct 24, 2021
    K1577555224305 , Oct 24, 2021 :
    It won't happen, you would have to live with it or downgrading is the only option.
  14. samjango
    Cupcake Oct 28, 2021
    samjango , Oct 28, 2021 :
    I love the update other than I can't use my phone for anything I use to as I cannot give any apps permanent permissions. I need to either have the mic in use without having a headset plugged in and the phone locked but the new update won't let me give the permissions even with developer mode on. Other then that I cannot stop the phone from telling me when an app is using the camera for example but I know that the app is using it because I chose to use it for that. I understand that this is for "security reasons" but I'm not stupid. Is there any way I can fix these problems?
  15. H1635539311651
    Cupcake Oct 29, 2021
    H1635539311651 , Oct 29, 2021 :
    Had really bad performance after upgrade, clearing Google Play Services app storage resolved the issue
  16. B1570187258700
    Cupcake Oct 30, 2021
    B1570187258700 , via OnePlus 6 , Oct 30, 2021 :
    Hi
    OnePlus 6 performing WORSE after android 11 stable update.
    1.Battery draining fast
    2.Camera app lags like hell
    3.Caller Id is not visible for first 5-6 sec the moment I receive calls
    4.Heating issue started
    Note: 50% storage is free. Yet mobile slow
    B1635096173504 and Mdelao like this.
  17. Mdelao
    Cupcake Nov 7, 2021
    Mdelao , Nov 7, 2021 :
    Hi, My phone is now súper slow and settings a d some apps are crashing, from time to time also get an error stating I don't have storage space and when retrying it works...
    Is there any fix around for these issues? These upgrade was really bad for my phone
  18. K1577555224305
    Honeycomb Nov 9, 2021
    K1577555224305 , Nov 9, 2021 :
    Check whether clearing cache and data of Google play services turns ok.
    Also update the results of experiment :)
  19. B1636542443931
    Cupcake Nov 10, 2021
  20. K1577555224305
    Honeycomb Nov 10, 2021
