408
OxygenOS 11 for the OnePlus 6 and OnePlus 6T
  1. B1635096173504
    Donut Nov 12, 2021
  2. ironass
    Lollipop Nov 13, 2021
    Shailender Sharma and Auristic like this.
  3. B1635096173504
    Donut Nov 13, 2021
  4. ironass
    ironass , Nov 13, 2021 :
    So why are you posting about OxygenOS 11.1.1.1 in this old thread for a different update, then?
  5. B1635096173504
    Donut Nov 13, 2021
  6. dsimoes
    Cupcake Nov 20, 2021
    dsimoes , Nov 20, 2021 :
    Hey guys..
    Another slow / sluggish post :( My OnePlus 6 was updated a few weeks back to 11.1.1.1 and it hasn't been a good experience.
    Not sure what to do. Really didn't want to Reset and rollback to 10, but it's becoming problematic. Is any hope for a magic update to fix all of this soon?!
  7. K1577555224305
    Ice Cream Sandwich Nov 21, 2021
    K1577555224305 , Nov 21, 2021 :
    Unfortunately No.
    But if you try to roll back to 10 ever, use an app called 'keepdata' and also take a backup of everything before rolling back to 10 in any case.
  8. kalyan.menda
    Cupcake Nov 21, 2021
    kalyan.menda , Nov 21, 2021 :
    After my one plus 6 updated to oxygen 11, I keep getting storage issue even I clear the data. It is forcing me to clear the data every day. Next I get the same problem. It is very slow now. I never buy OnePlus again.
    Please suggest me a solution. Should downgrade my OS. If yes, How should I do it? Any other solution please suggest.
    Do we loose the data and app settings when I rollback to 10?
  9. E1638248417093
    Cupcake Nov 30, 2021
  10. Q1547541130108
    Eclair Dec 4, 2021
    Q1547541130108 , via OnePlus 6T , Dec 4, 2021 :
    I have problems with warp charge. Stop charging dash mode. I don't know if the issue is software, socket usb/c or charger or cable... Please help! Many Thanks!
    One plus 6T Mclaren edition
  11. Z1638615139008 , via OnePlus 6T T-Mobile , Dec 5, 2021 :
    After android 11 update I am unable to send and receive media files on watsapp
    Also I am getting notifications on few apps that the app won't work on rooted device, previously everything was working smoothly
    Anyone faced similar issue
  12. Seaswirl724
    Cupcake Jan 15, 2022 at 7:06 PM
    Seaswirl724 , Jan 15, 2022 at 7:06 PM :
    I have the T-Mobile 6T on OOS 11.0.1.2 and wonder if anyone has installed the 11.1.2.2 Incremental Stable Update? The install instructions doesn't work on my phone, Settings/System Updates/Local Upgrade. I don't get this option in the Updater App. Can I Unzip and find an Executable file? I've done on computers but not sure about Android. Any suggestions,?
  13. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Jan 15, 2022 at 7:29 PM
    Artemus , Jan 15, 2022 at 7:29 PM :
    You have to unlock the phone then convert to global OOS before you can do manual updates. T-Mo blocks this on their firmware 'cause carrierlol.
    Shailender Sharma and Caomhin like this.
  14. Caomhin
    9 Series Expert, Participator of the Year Community Expert Jan 15, 2022 at 7:32 PM
    Caomhin , via OnePlus 9 Pro , Jan 15, 2022 at 7:32 PM :
    As you are on TMobile, the current build regions and versions will not work on your phone until TMobile offer their version for your phone. This is due to TMobile locking the bootloader to build versions they supply directly.
    Your best bet is to discuss in the OnePlus Community T-Mobile section.
    https://forums.oneplus.com/forums/t-mobile/
  15. Seaswirl724
    Cupcake Jan 16, 2022 at 12:24 AM
    Seaswirl724 , Jan 16, 2022 at 12:24 AM :
    Thank you for the info, I will look at that forum. My phone does tell me that the network is unlocked and can be used with any network but that probably doesn't have anything to do with the bootloader.
  16. Abhishek.001
    Honeycomb Jan 16, 2022 at 10:07 AM
  17. Abhishek.001
    Honeycomb Jan 16, 2022 at 10:08 AM
    gautyagi likes this.
  18. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Jan 16, 2022 at 10:50 AM
    Caomhin likes this.
  19. Abhishek.001
    Honeycomb Jan 16, 2022 at 10:56 AM
  20. K1577555224305
    Ice Cream Sandwich Jan 16, 2022 at 5:56 PM
    K1577555224305 , Jan 16, 2022 at 5:56 PM :
    Go to settings and type the city. But you must clear data once. If you haven't done it already.
