408
OxygenOS 11 for the OnePlus 6 and OnePlus 6T
  1. gautyagi
    Froyo Jan 16, 2022
    Abhishek.001 likes this.
  2. Mostafa mahmoud
    Cupcake Jan 22, 2022
  3. Dante69
    Froyo Jan 22, 2022
    VineetKamble likes this.
  4. Mostafa mahmoud
  5. K1577555224305
    Ice Cream Sandwich Jan 22, 2022
    K1577555224305 , Jan 22, 2022 :
    Unfortunately,This is a well-known issue.
  6. Caomhin
    9 Series Expert, Participator of the Year Community Expert Jan 23, 2022
    Caomhin , via OnePlus 9 Pro , Jan 23, 2022 :
    There is no known fix currently. But in fairness it's just a visual issue. So no biggie. Maybe Google might bring out a fix in the future as you will continue to receive Google Playstore, Google Services and Google Framework updates for a period of time.
    Artemus likes this.
  7. PohareNilesh
    Cupcake Jan 29, 2022
  8. K1577555224305
    Ice Cream Sandwich Jan 29, 2022
  9. K1577555224305
  10. rhyd1am
    KitKat Community Expert Jan 29, 2022
    rhyd1am , Jan 29, 2022 :
    First you'll need to update it to version 9.0.9 if you have a OP6 or 9.0.17 if you have a OP6T (this is required for preparation for Android 10). You can download it from here
    https://oneplusupdates.com/
    After downloading the file, you'll need to move it to root directory. To do this, open file manager and click on downloads. Long press on the downloaded file and then press the 3 dot menu in the top right corner. Select "copy"and then click on "internal storage", followed by "paste"
    After moving the file to your root directory, go to settings>system>system updates>hit the cog in the top right corner>local upgrade and select the file
    After 9.0.9/9.0.17 has been installed, go to the Oneplus support page http://www.oneplus.com/support and download the latest available build for the 6t. Install this in the same way as before.
    You should then be in a position to receive the latest build via an OTA update.
    Artemus, ironass and Caomhin like this.
  11. rhyd1am likes this.
  12. I1541007515863
    Froyo Feb 14, 2022
    Mostafa mahmoud likes this.
