408
OxygenOS 11 for the OnePlus 6 and OnePlus 6T
  1. sahiltherockstar
    Froyo Aug 11, 2021
    sahiltherockstar , via OnePlus 6T , Aug 11, 2021 :
    Facing phone app hi forced closed please tell me how to fix this?
  2. D.Sai Suhail Baba
    Jelly Bean Aug 11, 2021
  3. nastasedan
    Froyo Aug 11, 2021
    MALU8484 likes this.
  4. jeeva256
    Gingerbread Aug 11, 2021
    jeeva256 , via OnePlus 6 , Aug 11, 2021 :
    Settings > Buttons & Gestures > Navigation bar & gestures > Turn on the "Hide the Bottom bar
  5. harish3376
    Donut Aug 11, 2021
    harish3376 , via OnePlus 6T , Aug 11, 2021 :
    I do not face any issues.. Working perfectly fine
  6. jeeva256
    You'll get update normally or if you want you can download it from Oxygen updater manually ...
    BUT REMEMBER
    DOWNGRADING will ERASE all your data
  7. irzn1161
    Donut Aug 11, 2021
    irzn1161 , via OnePlus 6T , Aug 11, 2021 :
    well i take back my words about having no bugs....the first bug i have noticed is the Wifi...cant connect to my wifi network..tried forgetting and reconnecting but didnt work...please help oneplus....
    Z1541647230933 likes this.
  8. Ganasiva
    Eclair Aug 11, 2021
  9. D.Sai Suhail Baba
    D.Sai Suhail Baba , Aug 11, 2021 :
    Settings -- Search " adjustment " and you will find keyboard height adjustment .
    Clear cache and data of phone app and Power off your device -- long press on Power + Volume down button -- English -- Data and cache wipe -- Clear Cache and reboot , it will remove wastage from recovery and will fix some annoying bugs also.
    Yes AOD is given in Stable Build under regular settings rather than LAB.
  10. jeeva256
    Try to connect with SSID
  11. D.Sai Suhail Baba
    Settings -- System -- Reset Options and select " Reset Wifi , Bluetooth and mobile " and done .
    After completing the process follow this method :
    Power off your device -- long press on Power + Volume down button -- English -- Data and cache wipe -- Clear Cache and reboot , it will remove wastage from recovery. it will remove some annoying bugs also.
  12. Ahmad Hamad
    Donut Aug 11, 2021
  13. harshmahant
    Donut Aug 11, 2021
  14. D.Sai Suhail Baba
    AOD not working :
    Try as @ItsRavi25 said
    Go to settings > Apps and notifications > Show system apps > search for "OnePlus Wallpaper" > uninstall updates/ clear data.
    Update "Canvas" from the Play Store.
    Change wallpaper from canvas, this will trigger Ambient display.
    This method will help you to fix AOD issue.
    ItsRavi25 likes this.
  15. jeeva256
    rhyd1am likes this.
  16. dk1997
    Cupcake Aug 11, 2021
  17. Mariano_Di_Stefano_
    Mariano_Di_Stefano_ , Aug 11, 2021 :
    [QUOTE = "Pellziz, publicación: 23553404, miembro: 1788061"] Estoy en Beta 3, ¿cómo puedo volver a estable? [/ QUOTE]
    Misma pregunta. Tienes respuesta?
  18. jeeva256
    You have to downgrade to Android 10 which will wipe your data completely ..
    After that you can update to Os 11
    dk1997 likes this.
    pratik.gif , via OnePlus 6 , Aug 11, 2021 :
    Still not getting it.
  20. G_Raghu_Oza_QHSl
    Donut Aug 11, 2021
    pkaranth and boff_hell_Joe like this.
