433
OxygenOS 11 for the OnePlus 7 Pro and OnePlus 7
  1. G1604636413447 , via OnePlus 7 Pro , Mar 29, 2021 :
    If you're one of those who, like me, haven't received the Android 11 update as yet, count yourself lucky because the update we're going to get is going to be more bug-free than the one these people got. 😎 👍
  2. AdityaMagdum108
    Honeycomb Mar 29, 2021
    AdityaMagdum108 , via OnePlus 7 Pro , Mar 29, 2021 :
    I think you've not understood the process...
    For beta build... You have to first download it and locally upgrade it... The process might be displayed in a YouTube video...(I recommend TechiBee channel on YouTube)
    After upgrading it, your phone reboots and updates to beta channel... Then you start to get beta builds henceforth...
  3. AdityaMagdum108
    Shalin05 likes this.
  4. neelabhraj97
    Froyo Mar 29, 2021
    neelabhraj97 , via OnePlus 7 , Mar 29, 2021 :
    Umm, I think ur taking me for a noob but anyways that wasn't my question. Thanks for the advice bro!
  5. biglo30
    Froyo Mar 29, 2021
    biglo30 , via OnePlus 7 Pro , Mar 29, 2021 :
    Happening because you converted your phone to global. See others who did this have the same issue.
  6. Aakarshit.ty
    Froyo Mar 29, 2021
    Aakarshit.ty , via OnePlus 7 , Mar 29, 2021 :
    Do you hear what you're suggesting? Migrating from the stable to the beta build - seems legit LOL.
    You make a fair point about the language but I can't believe that a 'first' build coming after 7 months of first release of Android 11 has so many bugs and people on the official forum are suggesting to migrate to beta.
    I'm sorry, my phone is not your phone and I have better things to do in life than swapping our builds frequently. This is a forum post I'm writing in a long time because the quality of software OP is shipping sucks really bad and should not be termed stable.
  7. AdityaMagdum108
    Message me in the private messaging.... I'll then be able to understand your question in detail...
  8. SahilQureshi
    SahilQureshi , via OnePlus 7 , Mar 29, 2021 :
    I flashed through Oxygen Updater and believe me it is as stable as A10. Just need to soft reset and voila.
    Raan Saurav likes this.
  9. AdityaMagdum108
    The only reason I told you to migrate to beta... Is the reason that beta is showing better performance....
    If that's lol to you.. Then you're a lol
    Performance isn't a priority for you?
    And who told to switch channels often..?
    Continue in any one for a long period of time.. As the phone should get accustomed to any one you choose, which makes the phone perform better...
  10. Aakarshit.ty
    Froyo Mar 29, 2021
    Battery drain isn't normal. At least I haven't faced this type of drain in years by now.
    Regarding screen glitching - sure. I will make a YouTube video about it. Hope that's proof enough.
    There is absolutely no defense you can make on OnePlus's end if you separate the fact from fiction.
    Atanu Maji likes this.
  11. Aakarshit.ty
    Froyo Mar 29, 2021
    Stability is a priority for me and I'd like to remain on the 'stable' channel. If it still does not make sense, read my post again but slowly.
  12. Artemus.
    Community Hero 2020 Mar 29, 2021
    Artemus. , Mar 29, 2021 :
    Is your device model GM1915 by chance?
  13. 121192
    Cupcake Mar 29, 2021
  14. Sanjit biswad
    Froyo Mar 29, 2021
    Sanjit biswad , via OnePlus 7 , Mar 29, 2021 :
    Just download oxygen Updater and download specific zip file , and update via local update.
    But i think we should wait some days, new update have to many bug , just like heating issue, battery drain issue and many more.
    When solved this problem update will be available for all persons.
  15. AdityaMagdum108
    I just did my part to suggest something... Choosing it or not is your choice..
    Peace
  16. Rebel4you
    Gingerbread Mar 29, 2021
  17. Artemus.
    Perfectly safe and yes, you will receive future OTAs. All Oxygen Updater does is downloads the same OTA file onto your phone and lets you manually upgrade instead of waiting for the rollout to hit your device. I've used it plenty of times.
    Rebel4you likes this.
  18. Artemus.
    The reason: staged rollout. It's all explained in the first post of the thread. This happens every single update so it's nothing new.
  19. Shuvadeep_Sarkar , via OnePlus 7 Pro , Mar 29, 2021 :
    It's been a 5 days since the stage Roll Out Start . how much time it take to Receive to all the users ? Why these happen every time ...
    Raan Saurav and rebinrj like this.
