433
OxygenOS 11 for the OnePlus 7 Pro and OnePlus 7
  1. Sanjit biswad
    Froyo Mar 29, 2021
    Sanjit biswad , via OnePlus 7 , Mar 29, 2021 :
    Just check it OnePlus 7t forums , its already rollout for limited person, soon its available for all 7t user !!
    Mahroze likes this.
  2. Artemus.
    Community Hero 2020 Mar 29, 2021
    Artemus. , Mar 29, 2021 :
    It can take upwards of two weeks to get to everyone. Again, all is explained in the first post should you need more explanation. However, if you're that impatient to get it you can always use an app called Oxygen Updater to get the exact same OTA file at your own leisure.
    Raan Saurav likes this.
  3. Shuvadeep_Sarkar , via OnePlus 7 Pro , Mar 29, 2021 :
    I'm not impatient . I'm just asking . Thanks mate for the Reply
    Have a Nice Day !
    rebinrj likes this.
  4. Sanjit biswad
    Froyo Mar 29, 2021
    They're trying to solve the existing bug maybe! When its done it will be available for all of us. Its good to stay android 10 . Because oos 11 is too many bug, see all people complain about all that bug.
  5. Shuvadeep_Sarkar , via OnePlus 7 Pro , Mar 29, 2021 :
    May be But I'm excited to use the New UI 🥳
  6. Sanjit biswad
    Froyo Mar 29, 2021
    Then use oxygen Updater , its safe and easy process, just download and update via local update then do a soft reset, maybe all good .
    You can find oxygen Updater in playstore.
  7. U1577880995634
    Cupcake Mar 29, 2021
  8. allanbacudo
    Eclair Mar 29, 2021
  9. Artemus.
    All is explained in the first post.
  10. Zither74
    Donut Mar 29, 2021
    Zither74 , via OnePlus 7 Pro , Mar 29, 2021 :
    What I've noticed so far:
    Camera quality is MUCH better, especially Night Mode.
    Fingerprint sensor takes about twice as long to register.
    Low battery warning is almost unnoticeable; battery ran out during a video call and I never even noticed the warning.
    Battery life seems unchanged, which is good.
    Russky100 likes this.
  11. Udai Sharma
    Gingerbread Mar 29, 2021
  12. avslanch707
    Honeycomb Mar 29, 2021
    avslanch707 , via OnePlus 7 Pro , Mar 29, 2021 :
    I can 2nd that, I think mostly people with model GM1915 are the one with screen glitch bug and unstable 5gz WiFi connection. ( I m one of those people that initially had screen glitch problem, however after doing 2 factory reset it took care of itself) I still got the unstable wifi connection but 2ghz is equally more stable now. Just my 2 cents.
  13. sahilrana
  14. DhimasPrima1
    Donut Mar 29, 2021
    DhimasPrima1 , via OnePlus 7 Pro , Mar 29, 2021 :
    Hello fellas, I want give some updates 'bout OOS11. Before this, I'm so afraid to upgrade my system through oxygen updater regarding I haven't received the updates officially through OTA in setting.
    But because I can't wait to hold back any further to feel "new sensation", I finally update through oxygen updater. Here what I experienced after updating:
    1. Many lag found, like when scrolling and delayed when perform "back" action
    2. Heated too much
    3. Some apps not running properly
    4. The UI was not as seamless and fluid as many users expect
    5. Haptic feedback also found downgraded
    Then I found one superb solution that heal those issues, it's calling "factory reset after major update". Voilà, after doing factory reset, all of complaints from any users can't be found again. I could say that OOS11 is more better than OOS10 now. Battery life better, no more overheating, camera quality better, haptic feedback also better and of course OOS11 is more fluid & seamless.
    So, whoever that still waiting the update come in ur system, you can follow my suggestions:
    1. Backup ur data using oneplus switch app, move the backup files to your PC/laptop or you can backup through setting with your google drive and google photos
    2. Install oxygen updater app
    3. Download the update there
    4. Install it via local upgrade
    5. Perform factory reset
    6. Place the backup files back into ur 1+ device again
    7. Restore it through oneplus switch app
    (Or if u backup using gdrive, just restore when you in setup mode after resetting)
    8. Enjoy the new experiences without some problems (I hope so) while waiting further updates from oneplus teams
    Arun_Kashyap likes this.
  15. rebinrj likes this.
  16. Prathmesh176
    Prathmesh176 , via OnePlus 7 , Mar 29, 2021 :
    Soft reset in the sense u just wiped ur cache memory right?
  17. SahilQureshi
    SahilQureshi , via OnePlus 7 , Mar 29, 2021 :
    No. I wiped System and Apps data. Not photos and all. Deselect erase internal storage.
    Keep Google Backup so that apps will get reinstalled while set-up process after wipe.
  18. Prathmesh176
    Ok bro Thankx.. Hows the performance.. Stable as os10
  19. SahilQureshi
    Feels more fluid than OOS 10. I miss few things like Haptic feedback on double tap to wake and OnePlus Slate fonts.
    Prathmesh176 likes this.
  20. T1570024183543
    Froyo Mar 29, 2021
