433
OxygenOS 11 for the OnePlus 7 Pro and OnePlus 7
  1. TommyHammy
    Honeycomb Mar 29, 2021
    TommyHammy , Mar 29, 2021 :
    As with most reviews and things, you only usually hear about the bad, or if something goes wrong. Most of the time it's user error. So it seems the bad reviews of this release outweigh the good, but in reality it's probably the opposite.
  2. ymkrb8
    Donut Mar 29, 2021
  3. Abhi_17_09
    Cupcake Mar 29, 2021
  4. DelBoyJamie
    Gingerbread Mar 29, 2021
    DelBoyJamie , Mar 29, 2021 :
    Anyone else not able to log into OnePlus account in settings?? I can log in no problem online just not in settings. So I'm stuck with the
    "Log into account, log into OnePlus to explore your customized journey"
  5. Kruzer
    Kruzer , via OnePlus 7 , Mar 29, 2021 :
    I think it will be fixed in next update
    vermajai93 likes this.
  6. akks
    KitKat Mar 29, 2021
    akks , Mar 29, 2021 :
    There is no such feature
    x_jayreghe_x likes this.
  7. Yosef..83
  8. AdityaMagdum108
    AdityaMagdum108 , via OnePlus 7 Pro , Mar 29, 2021 :
    First of all take it cool...
    We sorted out the problem... You're just flogging the dead horse for no reason..
    And why are you unnecessarily intervening when we already had it talked out.. This is the kind of behaviour that people hate...
    Whatever you want to say, never use enmity to convey your feelings.. It should be a mutual correspondence
    MATE!🤕
  9. Yosef..83
  10. Shalin05
    Tedinetto and YAJIV4VIJAY like this.
  11. C1614361085493 , via OnePlus 7 Mirror Gray , Mar 29, 2021 :
    After Downgrade My Oneplus 7.
    Then I Will Wait For Stable Os 11.
    That Is Why I Need Downgrade Solution.
  12. akks
    KitKat Mar 29, 2021
    What bug, bot?
  13. Insane_Butcher
  14. rubenquattro
    Froyo Mar 29, 2021
    rubenquattro , Mar 29, 2021 :
    Go to Beta post and there you could find the zip file to rollback . I used and it went OK. With that rom you could go to Beta 2. In my case, I used that rollback rom to go to android 10 and then I go to Android 11 withouot problems! In my case, A11 goes fine, some minor issues but in my case nothing critical!
  15. maheshsdahifale
    maheshsdahifale , via OnePlus 7 Pro , Mar 29, 2021 :
    I have updated using Oxygen Updater and haven't faced any issues regarding the OS.
    iamvaibhav10 likes this.
  16. C1614361085493 , via OnePlus 7 Mirror Gray , Mar 29, 2021 :
    How i find beta post.
    Can u help me.
  17. YAJIV4VIJAY
    YAJIV4VIJAY , via OnePlus 7 Pro , Mar 29, 2021 :
    You can just simply download the latest stable OOS 11 from oxygen os updater app, reset and clear cache your device, then install the downloaded package directly from open 4. I did the same.
  18. C1614361085493 , via OnePlus 7 Mirror Gray , Mar 29, 2021 :
    Thanks Buddy
    YAJIV4VIJAY likes this.
  19. rubenquattro
    Froyo Mar 29, 2021
