433
OxygenOS 11 for the OnePlus 7 Pro and OnePlus 7
  1. vrakk
    Donut Mar 29, 2021
    vrakk , via OnePlus 7 Pro , Mar 29, 2021 :
    People who updated and did a hard reset please give your user experience, main concern is Call reception, Loud speaker volume and Haptics.... All the following good or bad now?
  2. AnkushMahe
    Froyo Mar 29, 2021
    Raan Saurav likes this.
  3. harshal2006
    Eclair Mar 29, 2021
    harshal2006 , via OnePlus 7 , Mar 29, 2021 :
    Yes I have facing same issue
  4. Danzo01
    Eclair Mar 29, 2021
    Danzo01 , via OnePlus 7 , Mar 29, 2021 :
    Battery draining so fast
  5. speed7
    Donut Mar 29, 2021
    speed7 , via OnePlus 7 , Mar 29, 2021 :
    It's not happening for me, brother.
    I don't know what to say.
    Just give it a day or so.
  6. tprabhukiran
    Eclair Mar 29, 2021
  7. gdsingh94
    Jelly Bean Mar 29, 2021
    gdsingh94 , via OnePlus 7 , Mar 29, 2021 :
    On OnePlus 7 everything works fine after a factory reset.. don't know about 7 pro..
    vrakk likes this.
  8. Adi_2019
    Honeycomb Mar 29, 2021
    Adi_2019 , via OnePlus 7 , Mar 29, 2021 :
    Colour calibration is more like OOS 9 now. But Colours are better than OOS 10. Natural is supposed to be slightly warmer. Vivid before was far off from correct colours, now it's good. If you want to keep colours natural but less warm white balance, switch to advanced mode and select sRGB. It's very accurate.
    harshal2006 likes this.
  9. Netsky60
    Arifhoque likes this.
  10. Netsky60
    Netsky60 , Mar 29, 2021 :
    Same on Pro version ;)
  11. Adi_2019
    There is no such bug in OS. It could be some issue with your particular device. Wipe cache memory of device. If the issue still persists, better do a factory reset.
  12. Arifhoque
    Cupcake Mar 29, 2021
    Netsky60 likes this.
  13. gaursayyam
    Froyo Mar 29, 2021
  14. Insane_Butcher
    Insane_Butcher , via OnePlus 7 Pro , Mar 29, 2021 :
    Thanks a lot for your feedback. Can you kindly share if you have the following issues?
    1) slow media loading speed in chats/groups in Telegram
    2) Photographs in the gallery app don't show up as is. I used to see the number of files calculated - and all materials required some time to show up.
    3) When accessing the shelf - glitchy interface.
    4) OnePlus launcher stops responding
    5) Increased battery consumption
  15. Sairam Venkata
    Froyo Mar 29, 2021
    Sairam Venkata , via OnePlus 7 , Mar 29, 2021 :
    After update battery draining issue , camera quality bad no heating issue .
    There are new features like horizon light
    canvas in customization settings
  16. speed7
    Donut Mar 29, 2021
    Hello,
    1. Not an issue at all.
    A caveat: I rarely use Telegram, mostly for updates so my conversations do not have a lot of media.
    2. I do not use the OnePlus Gallery app. I've been using a different application for the past 3-4 years. No issue in this app or with Google Photos.
    3. I disabled the Shelf - I had no use for this feature. Unfortunately, I won't be able to help on this.
    4. No issues with OnePlus launcher. Has not crashed even once in my ~2 hours of usage after the Android 11 update.
    5. Normal battery consumption so far. I lost about 15% during the update and the 10 mins after the first boot. But, it's been normal after that.
    Insane_Butcher likes this.
  17. cr1411
    Froyo Mar 29, 2021
  18. Harshitg675
  19. Brovgard
    U1549078778762 likes this.
