435
OxygenOS 11 for the OnePlus 7 Pro and OnePlus 7
  1. cran12
    Froyo Mar 29, 2021
    cran12 , Mar 29, 2021 :
    I agree, been in beta for a while and rolled back to 10 beta 19 and feel it is much smoother.
  2. Suraj gurav 007
    Ice Cream Sandwich Mar 29, 2021
    Suraj gurav 007 , via OnePlus 7 Pro , Mar 29, 2021 :
    I have updated my device to latest version android 11 but after use of 2 hours i didnt get any issue
    All is going better and its smooth
    Checked every app every setting
    No problem att all
    I have downloaded official OTA update
    Didnt have any problem
    But i have some suggestion
    If you are downloading update
    Download it on first goo
    Dont do play pause for downloading update
    And another note
    I didnt do any factory reset
    Fone is smooth and update is very good
    No no issue
  3. Yusri951 likes this.
  4. Ambranesshwar
    Gingerbread Mar 29, 2021
  5. Dakshp99
    Cupcake Mar 29, 2021
    isohaibkhan007 likes this.
  6. isohaibkhan007
    isohaibkhan007 , via OnePlus 7 Pro , Mar 29, 2021 :
    Getting 3 hours 36 minutes screen time after android 11 update that to my resolution is set on fhd and 60Hz
  7. rajakakash
  8. isohaibkhan007
    Till the time OnePlus provides that feature it will be the era of android 30
  9. stalap
    stalap , via OnePlus 7 , Mar 29, 2021 :
    After update to android 11
    1. Slightly yellow colour on screen (2%)
    2. Double tap wake screen little bit slow
    These problems found in today's use
    No battery drain issue or any other app issue not found
    T1570024183543 likes this.
  10. MadyKarthi
    Honeycomb Mar 29, 2021
  11. PRAMOD_HARKARE
    Eclair Mar 29, 2021
    PRAMOD_HARKARE , via OnePlus 7 Pro , Mar 29, 2021 :
    Get it with oxygen updater....install oxygen updater and you will get...
  12. Danzo01
    Eclair Mar 29, 2021
  13. G_Hashmi_Faiq_UqhY , via OnePlus 7 Pro , Mar 29, 2021 :
    There is an update for the issue. If you put 90 hz + qhd display resolution then there is no issue with screen. I tried it and it works fine. If anyone tried it please post ur results.
  14. Suraj gurav 007
  15. Danzo01
    Eclair Mar 29, 2021
  16. Suraj gurav 007
  17. Danzo01
    Eclair Mar 29, 2021
    Danzo01 , via OnePlus 7 , Mar 29, 2021 :
    I am taking about one Plus 7 not pro why canvas is not working that's why?
  18. Suraj gurav 007
