435
OxygenOS 11 for the OnePlus 7 Pro and OnePlus 7
  1. alygillani
    Cupcake Mar 29, 2021
  2. littldough
    littldough , via OnePlus 7 Pro , Mar 29, 2021 :
    At least you can answer your calls. Mine are delayed 4-5 seconds too and when I go to answer nothing happens! The call doesn't 'start' when I hit answer and it goes to my voicemail. Pretty unbelievable they forgot to check if the phone worked on a cellphone.
  3. rahilsayed
    Eclair Mar 29, 2021
    rahilsayed , via OnePlus 7 Pro , Mar 29, 2021 :
    Hmmmmm.... I am fan as well, no hurries.
    Russky100 likes this.
  4. G_Hashmi_Faiq_UqhY , via OnePlus 7 Pro , Mar 29, 2021 :
    For me I tried FHD+60hz and QHD+90hz. Both removed screen issues. Only issue was when I put FHD+90hz. Screen zooms in and out. And if I lock the phone then screen never turns on. But in other 2 options working fine.
  5. R.Peter
    Ice Cream Sandwich Mar 29, 2021
    R.Peter , via OnePlus 7 Pro Mirror Gray , Mar 29, 2021 :
    Have the same thoughts. Word by word.
    ArjunpalSingh likes this.
  6. alygillani
  7. sia_0
    Gingerbread Mar 29, 2021
    sia_0 , via OnePlus 7 Mirror Gray , Mar 29, 2021 :
    So I don't know if this is the issue with my Phone or with others but does anyone feel the haptics kinda messed up after the update to Oxygen OS 11?
    In oxygen os 10, the haptics were super smooth and now after the update, it feels like I'm hitting a glass slab. Please let me know if you guys have the same issue so that we can let the team know because this is really a deal breaker :(
  8. alygillani
    alygillani , via OnePlus 7 Pro , Mar 29, 2021 :
    Much appreciated.
    Somebody just quoted that i have converted phone i.e different model and flashed with Global rom.
    Any opinion on that?
  9. Suneel@
    Eclair Mar 29, 2021
  10. brian.sedore
    brian.sedore , via OnePlus 7 Pro , Mar 29, 2021 :
    You could try the Google Phone dialer. I haven't tried it on OnePlus devices yet, but I think it is available. I also don't know if it will make a difference, but it's something to try.
  11. alygillani
    Much appreciated.
  12. G_Hashmi_Faiq_UqhY , via OnePlus 7 Pro , Mar 29, 2021 :
    I am also using same. T-mobile version converted to global. Mostly from comments model GM1915 have the issue with screen never turns on after locking the phone. I tried this and there is no problem at all. I don't know much about the versions and conversions have any impact. But I tried it and everything working fine.
  13. alygillani
    I had updated it to beta version back then and faced thsi unlocking issue.
    But this OTA didn't have that specific bug.
    Stay blessed.
  14. G_Hashmi_Faiq_UqhY , via OnePlus 7 Pro , Mar 29, 2021 :
    That's good. Only some phones have this issue. Sadly I am one of them. Hope they will release hot fix soon.
    alygillani likes this.
  15. georgesunnyt
  16. littldough
    Yeah I tried that. Does same thing so doesn't seem to be an app issue. When I was on beta I tried everything to get it work, reverted back to stable 10, then, phone worked, then cleared cache and siideloaded to beta 3, phone didn't work. So I went back to stable 10 and waited for stable 11 which got pushed to my phone this morning. Phone doesn't work again. So it seems to be something with OS11. I'm on GoogleFi so don't know if that would have something to do with it, but it shouldn't.
  17. F1570774041931
    F1570774041931 , via OnePlus 7 Pro , Mar 29, 2021 :
    Updated to Android 11
    Issues
    1) Battery Drain and over heating
    2) Though set to 90hz it isn't as smooth as it was in android 10
    3) Size of text it feels like it is zoomed so changed font settings to small from default.
    4)Camera quality of pics is downgraded
    5) Audio is also affected compared to previous version
    There are many issues even in this stable update I hope OnePlus Will resolve these in future updates for now disappointed with OnePlus even after so much delay the stable update Is not satisfactory.
    rayprayas03 likes this.
  18. L1563686673246
  19. sarahmic
    Honeycomb Mar 29, 2021
    sarahmic , Mar 29, 2021 :
    OnePlus 7 Pro:
    Got the update and things working fine EXCEPT for Horizon Light.
    I already had that option switched on but Horizon light does not work for me unfortunately. :confused:
  20. ogoditsnick
    ogoditsnick , via OnePlus 7 Pro , Mar 29, 2021 :
    I'm having 1 major issue with this update
    Callers are complaining of an echo on their end. Only while I'm on the earpiece though. It goes away with while on speaker or bluetooth
    Anybody else having this issue? Any suggestions on how to fix it?
    Rjshah2300 likes this.
