435
OxygenOS 11 for the OnePlus 7 Pro and OnePlus 7
  1. Adg123456789
    Gingerbread Mar 31, 2021
    Adg123456789 , via OnePlus 7 Pro , Mar 31, 2021 :
    Clean installation is recommended at the very first sight indeed 🤗
  2. bingi46
    Honeycomb Mar 31, 2021
    Shalin05 likes this.
  3. Adg123456789
  4. huong1990
    Cupcake Mar 31, 2021
  5. RajendraRathore
    RajendraRathore , via OnePlus 7 Pro , Mar 31, 2021 :
    My phone (OnePlus 7 Pro, 12GB RAM + 256GB ROM) is hitting so much after this update. It is hitting when we use any application, charging phone etc. Before this update it was not the case. There was nothing like hit before upgrade.
    Please look into this as soon as possible.
  6. Insane_Butcher
    Insane_Butcher , via OnePlus 7 Pro , Mar 31, 2021 :
    Basically the more bug reports you all do the more probability that OnePlus actually notices the problem and issue a hot fix for overheating while charging and battery drain. Because I see that many of you have encountered the same kinda problem .
  7. RajendraRathore
    Exactly same issues with my phone after Android version update to 11.
  8. RajendraRathore
    Same issues with me after update, before update everything was fine.... please keep your voice raise.....we need an urgent fix...
  9. RajendraRathore
    Are you from One Plus team?
  10. Insane_Butcher
    I am end user like you. Just pointing out that OnePlus developers and bug Hunters do not necessarily trace down each thread to identify the most common issues. They only count the bug reports or well, inquiries that were sent using reporting tools.
    rathore24 likes this.
  11. G_Nitesh_Kumar_bXKl
  12. G_Nitesh_Kumar_bXKl
  13. G1593685875511 , via OnePlus 7 Pro , Mar 31, 2021 :
    I have managed to solve issue by disabling Double-Tap to Wake.
  14. Vijay_Narasimha
    Eclair Mar 31, 2021
    Vijay_Narasimha , via OnePlus 7 , Mar 31, 2021 :
    It doesn't. Insight option only for ambient display. No AOD yet.
    Kriegir likes this.
  15. RajendraRathore
    Okay, thanks! What is the best way to escalate the issue so that One Plus team can look into our issues on high priority? Please advise.
  16. Insane_Butcher
    Report bugs using the report tools. You will be required to reproduce the problem. Alternatively you can send bug reports or simply contact Bug Hunters directly via email: [email protected]
  17. Hardik47
    Eclair Mar 31, 2021
  18. RajendraRathore
  19. Abhi_17_09 likes this.
  20. GOLYAA
