435
OxygenOS 11 for the OnePlus 7 Pro and OnePlus 7
  1. muraliece31
    Cupcake Mar 31, 2021
  2. G_Dóri_Zovits_Fmmi
  3. M1560335188599
    Gingerbread Mar 31, 2021
    M1560335188599 , Mar 31, 2021 :
    BS! OP failed, admit it!!
    B k likes this.
  4. MR._.ROHIT._.VAR , via OnePlus 7 Mirror Gray , Mar 31, 2021 :
    I've been facing this issue how come the image quality had decreased.
    2.Full ui lag
    3.over heating
    4.it is taking more than 1.2hr for full charge previously it was about 50
    Bhatsaurabh07 likes this.
  5. gdsingh94
    Jelly Bean Mar 31, 2021
    gdsingh94 , via OnePlus 7 , Mar 31, 2021 :
    Factory reset is recommended in every phone after major updates.. but people don't do it and later cry that they are facing issues...
    anchits28 likes this.
  6. s0lanki7
  7. AnkushMahe
    Froyo Mar 31, 2021
  8. kmaier
    Honeycomb Mar 31, 2021
    kmaier , via OnePlus 7 , Mar 31, 2021 :
    If you do a backup before moving from beta to stable, do you still lose all your app passwords?
  9. s0lanki7
    s0lanki7 , via OnePlus 7 , Mar 31, 2021 :
    Reinstall.
  10. gdsingh94
    Yes. You lose everything. app password are generally saved in google account if you have enabled it...
  11. AnkushMahe
    Froyo Mar 31, 2021
    AnkushMahe , via OnePlus 7 , Mar 31, 2021 :
    I Do not agree. Factory reset is a very complex and lengthy task. Backing up everything, re login to all apps.. setup work profile and other work apps. These updates are designed to upgrade OS seamlessly.
    Bhatsaurabh07 and biglo30 like this.
  12. T1582127916374 , via OnePlus 7 Pro , Mar 31, 2021 :
    Idk, I didn't do a backup and my passwords and so on were stored on my Google Drive account. When I introduced my email address again, it gave me the option to restore a backup from Google Drive. At least all my passwords, wifi networks, apps, etc were there. It was a suprise for me though. AND if you do a backup but don't store this backup on a computer, you will lose it because all data are wiped. I suppose that if you do a backup, store it on a laptop, update and then put the folder back into the phone, you'll be able to recover everything.
  13. pjurrm
  14. gdsingh94
    Download oxygen updater from play store..
    muraliece31 likes this.
  15. zix47
    Vinod_cr7 likes this.
  16. TNHS
    TNHS , via OnePlus 7 Pro , Mar 31, 2021 :
    I was update 4 hour ago, my device is normally. Just one thing, i feel os 11 is slowly than os 10. But i think Oneplus team will be fixed soon. Don't forget hard reset after update, good luck everyone :33
  17. akks
    KitKat Mar 31, 2021
  18. TommyHammy
    TommyHammy , Mar 31, 2021 :
    Ok. List 100 of them. I would like to know.
    JNiemi and Dmitrov like this.
  19. TommyHammy
    Seems you don't know what you're talking about.
  20. sahilrana
    Tedinetto likes this.
