435
OxygenOS 11 for the OnePlus 7 Pro and OnePlus 7
  1. surajit20
    Froyo Mar 25, 2021
  2. pspkid
    Cupcake Mar 25, 2021
  3. AdityaMagdum108
    Honeycomb Mar 25, 2021
  4. AdityaMagdum108
    AdityaMagdum108 , via OnePlus 7 Pro , Mar 25, 2021 :
    Not that i can't find it....I have found it and enabled it... But it doesn't support yet
  5. rayprayas03
    Ice Cream Sandwich Mar 25, 2021
    rayprayas03 , Mar 25, 2021 :
    You can find the file from Xda i had also downloaded from there few days back
    Sreeram_Nath likes this.
  6. Lokesh694
  7. yashu0069 likes this.
  8. untung.us
    Donut Mar 25, 2021
  9. dikoscilator
    dikoscilator , via OnePlus 7 , Mar 25, 2021 :
    Please factory reset your device before installing a clean os not that it is mandatory but for your own good will
    I backed up my data on laptop
    Did a hard reset from boot menu on a Android 10
    Upgrade to Android 11 and one more time did the factory reset this really helps with small problem and bugs which occur here and there although i did experience some bugs
    Where the music title from amazon music comes back to notification after intervals of time second that double tap to wake up doesn't work 100 percent of the time
    Canvas works 50 percent of the time
    And speaking of battery give the phone a few cycles of 90+ percent of charge although i did notice a slightly more drainage form this version, when there are multiple notification received the individual notification cannot be expanded to reply, it happened 70 percent of the time
    (Yes i will report this bugs)
    yashu0069 and Artemus like this.
  10. K1616691781053
    adrian.borza and Nazmul_xodiac like this.
  11. DeeJaaWoo
  12. maheshsdahifale
    Gingerbread Mar 25, 2021
  13. Andrewas
  14. Miraj98
  15. georgesunnyt
    georgesunnyt , via OnePlus 7 Pro , Mar 25, 2021 :
    First impressions: font seems to be a little big for my liking compared to oos 10. Everything seems fine so far stability wise. I think the Dev's have done a good job.
    yashu0069 and hc.hiren like this.
  16. E1616688260137
  17. Bierten77
    Froyo Mar 25, 2021
  18. cran12
    Froyo Mar 25, 2021
    cran12 , Mar 25, 2021 :
    Incoming calls still going to speakerphone!!!!
    I can't believe this started since ob1. I've use beta for a year and just wiped my phone and did a clean install figuring stable would fix it. I wasn't to concerned or upset before knowing I was on beta but damn! This is supposed to be a stable build and the phone portion of the phone doesn't work correctly!
  19. arkankit
    Donut Mar 25, 2021
    arkankit , Mar 25, 2021 :
    expected
