435
OxygenOS 11 for the OnePlus 7 Pro and OnePlus 7
  1. Sebixu_ , via OnePlus 7 Pro Nebula Blue , Mar 25, 2021 :
    It is in beta. It works better with faces pics. This option is in the personalization sección. When yoj select the option, hoy will have yo select a pic.
    When the Canvas is on, hoy will see in the lock screen that image in white and black, but only the borders of the face (eyes,mouth,etc.). When hoy unlock the device, the pic turns to normal
  2. fcarmona
    Gingerbread Mar 25, 2021
    fcarmona , via OnePlus 7 Pro , Mar 25, 2021 :
    I was looking how to install the update although I haven't received it, but, after 27 pages I have decided not to upgrade.
    Will keep my 7P on Android 10 and wait for more information about all the issues reported. said:
    I consider this oficial release as Beta 5
    iamvaibhav10 likes this.
  3. ghughson
    Eclair Mar 25, 2021
    ghughson , via OnePlus 7 Pro , Mar 25, 2021 :
    I did not. I planned to if I happened to run into any serious issues, but it's running so smoothly that I haven't felt the need to.
  4. Yayan14
    Cupcake Mar 25, 2021
  5. Dr.Narcissist
    Dr.Narcissist , via OnePlus 7 Pro , Mar 25, 2021 :
    Updated just Today
    Cons being: Degraded camera quality.
    Phone seems slower and there r animation lags.
    Has become a snail: it is now taking significant-> naked eye difference time even while creating a folder or renaming it.
    To many bugs...needs an updated package ASAP😕
    T1570024183543 likes this.
  6. R1587996875587
    R1587996875587 , Mar 25, 2021 :
    A bit worried after reading the decreased camera quality comments. Should I even update or not? Not that I have the update available anyway.. [e]1f601[/e]
  7. Serenity123
    Eclair Mar 25, 2021
  8. M1616703213458
    M1616703213458 , via OnePlus 7 Pro , Mar 25, 2021 :
    Buenas, he actualizado mi dispositivo a la versión estable y resulta que tengo un problema con el botón de encendido, cuando lo presiono el teléfono apaga la pantalla pero luego que vuelvo a presionar el botón encendido para usarlo, se queda en pantalla negra pese a que siento las notificaciones y que todo funciona bien, más no veo nada, porque la pantalla queda negra, alguien con este problema?
  9. AaronLobo
    AaronLobo , via OnePlus 7 Pro , Mar 25, 2021 :
    Guess that's how it's supposed to be?
    ShadowBolt09 likes this.
  10. ShadowBolt09
    Jelly Bean Mar 25, 2021
    AaronLobo likes this.
  11. TommyHammy
    Honeycomb Mar 25, 2021
    TommyHammy , Mar 25, 2021 :
    Quite a few annoying bugs in the stable release I see. I think I'll hold off updating for a while yet then!
  12. geofallas
    geofallas , via OnePlus 7 Pro , Mar 25, 2021 :
    Well I updated like 4 hours ago, and everything is working great, the battery looks normal, but the system work faster. Not heating, not camera crash. The only thing I miss is the battery icon circle.
  13. geofallas
    Creo a qué tienes seleccionado en personalización pantalla ambiente un fondo negro, selecciona otro e intenta a ver cómo te va.
    M1616703213458 likes this.
  14. brian.sedore
    Ice Cream Sandwich Mar 25, 2021
  15. TommyHammy
    enjoy the bugs...
  16. ghughson
    Eclair Mar 25, 2021
    This one?
    geofallas likes this.
  17. the_anandude
    Donut Mar 25, 2021
    the_anandude , via OnePlus 7 , Mar 25, 2021 :
    Yea.im facing the same issue. It feels so cheap and weak when using
    RaQeeb_ likes this.
  18. brian.sedore
  19. ByRapaz , via OnePlus 7 Pro Nebula Blue , Mar 25, 2021 :
    ¡Hola!
    Te recomiendo que hagas un reset por que ese bug ni estaba presente en las betas.
    Si es cierto que si mantienes presionado el botón de encendido, por defecto, se abre Google Pay así como en la parte superior de la pantalla podrás ver el botón de emergencia, reiniciar y apagar.
    Si haciendo reset te persiste el bug, además de reportarlo, te recomiendo que reinstales la Rom.
    ¡Un saludo!
  20. M1616703213458
    Gracias!
    ByRapaz. likes this.
