435
OxygenOS 11 for the OnePlus 7 Pro and OnePlus 7
  1. MichaelChernega
    Cupcake Mar 28, 2021
    Vsls.St likes this.
  2. Bilalkhan4
    Eclair Mar 28, 2021
  3. Bilalkhan4
    Eclair Mar 28, 2021
    Bilalkhan4 , via OnePlus 7 Pro , Mar 28, 2021 :
    Yes , I am On Beta Build and it seems to be working fine for me
  4. superture
    superture , via OnePlus 7 Pro , Mar 28, 2021 :
    1000 where is update/use oxygen updater/is oxygen update safe?
    500 battery drain or any other usual complaint
    450 OnePlus suck/will sell phone/Samsung is so much better
    50 actually good comments
    MaxLn likes this.
  5. SAHIL_MEENA
    Donut Mar 28, 2021
    SAHIL_MEENA , via OnePlus 7 Pro , Mar 28, 2021 :
    Yes I too have such issues with My OnePlus 7 pro , Android 11 update really disappoints me either.
    Colourful mode in customisation is gone , I used to love that theme in settings !
    I am thinking of going back to OS10 but that will wipe my all data and consume more time !
  6. R. Dave T.
    Donut Mar 28, 2021
    R. Dave T. , via OnePlus 7 Pro , Mar 28, 2021 :
    Yes I'm having all kinds of crazy display issues, sometimes getting locked out of my phone because fingerprint reader disappears to lower right hand side out of view. The code to get into my phone does the same so I'm unable to unlock phoned. Have to hold power button and volume up button same time to reboot phone then it works again for a for a few hour. I really hope they fix this fast. Its driving me nuts 😁
  7. Z1563881983375
  8. Netsky60
    Ice Cream Sandwich Mar 28, 2021
    Netsky60 , Mar 28, 2021 :
    Then check the forum first ! Be smart ;)
  9. TommyHammy
    Honeycomb Mar 28, 2021
    TommyHammy , Mar 28, 2021 :
    That's an unfair comment. Like most reviews and stuff, you only hear about the BAD stuff. How many thousands of people do you think are happy with the update and are facing no problems?
    Russky100 likes this.
  10. hgrev
    hgrev , Mar 28, 2021 :
    I have oneplus 7 pro T-Mobile edition. how can I update to OxygenOS 11 manually? I don't want to wait and oxygen updater doesn't support my model
  11. MelvinAbes
    biglo30 and Vijay_Narasimha like this.
  12. Netsky60
    Did you even read this thread or not ? o_O
    OS11 is stable, smooth and there's not battery drain !
    - Do a wipe cache (no data will be lost)
    - Check if a NON Android 11 compatible app is draining your battery
  13. Netsky60
    update all your apps
    wait for system to be fully updated
    Sarthak Vishu likes this.
  14. UnicornZ
    UnicornZ , via OnePlus 7 Pro , Mar 28, 2021 :
    Add your comment to the list of useless comments.
    superture likes this.
  15. MelvinAbes
  16. OnePlusA11
    Froyo Mar 28, 2021
  17. Legend189
    Froyo Mar 28, 2021
    Legend189 , via OnePlus 7 Pro , Mar 28, 2021 :
    I am facing really bad lag while scrolling its ok sometimes but then outa no where it just drops frames and lags while scrolling. I did a clean install erased everything still its happening. Anyone else having this issue?
  18. Netsky60
    I had this behavior during the first 15 mn. It's now ok and smooth as butter.
