509
OxygenOS 11 for the OnePlus 7T Pro and OnePlus 7T
  1. C1616598611014
    Cupcake Mar 24, 2021
  2. Aniketjoshi0510 , via OnePlus 7T Pro , Mar 24, 2021 :
    Should I update to 11 version as if now I haven't updated the phone yet, is there any McLaren theme available and any major bug came to your notice??
  3. F1579226717741 , via OnePlus 7T Pro , Mar 24, 2021 :
    Oneplus programmed the issues I'm having. On my android one this shortcut was optional. Soft press button and heavy phone makes for many accidentally actived vibrate mode/screen shoots. The extra screen shoots I can live with.
  4. Louisbaecke510
    Honeycomb Mar 24, 2021
    Louisbaecke510 , via OnePlus 7T Pro , Mar 24, 2021 :
    No problem with it
  5. Louisbaecke510
  6. V1616350648526 , via OnePlus 7T Pro , Mar 24, 2021 :
    Updated Today **** MAJOR ISSUE ****
    After the upgrade, it never took the password. Always said wrong password. Even when I was entering the correct password.
    Luckily,took the backup of my photos and videos.Vut didn't take the backup of contacts (but ok)
    I had the work profile set up and it makes me set up password mandatory (not PIN). If you can remove passwords, remove it and then try to upgrade.
    I tried restarting, powering off and start. Even after that it didn't take the password and always said incorrect password.
    Finally did a hard reset which erased everything.
    Power off ----> press and hold volume down+power key
    After agreeing to reset, when it booted up it asked me to enter the last password used as the device was reset.
    It took the password this time. (The same password which I was entering before).
    Seriously it's a messed up update!!!!
    Don't know why they took so long and what they did to release a broken update.
    Definately moving back to iPhone in couple of years.
  7. P1578106162068
  8. Q1571383650025
  9. F1579226717741 , via OnePlus 7T Pro , Mar 24, 2021 :
    I've had one issue solved with oxygenOS 11. With the last version OxygenOS 10 I could lose navigation buttons when using keyboard. At least that's fixed. The navigation button issue was only the last 3weeks.
  10. devourerOfBits80
    devourerOfBits80 , via OnePlus 7T Pro , Mar 24, 2021 :
    You are wrong. OnePlus is the best brand I've ever seen. OnePlus always releases software without any bugs, according to its promises in time and with the all features like the AOD. If you don't agree with this opinion, your intelligence is probably too low to understand how the OnePlus perfectly works, delivers products of the best quality, and respects its customers. 😂😂😂
    So... If you have a different point of view than the OnePlus funs, you are wrong! Why you are wrong? Because you are wrong! 🤣🤣🤣
    Regards,
    B k likes this.
  11. devourerOfBits80
    Please install OxygenOS Updater app from the Google Play store, and then you will be able to install update.
  12. Thanika237
    Thanika237 , via OnePlus 7T Pro , Mar 24, 2021 :
    Getting over heated . Fonts are become medium size in small size settings . Call screen displays after 5 seconds of ringtone . It's irritated . Need to wait 5-10 seconds to know who is calling .
  13. Movalis
    Movalis , Mar 24, 2021 :
    Does anyone experienced a geotag photo problem? I have everything turned on and after update to A11, location is totally of especially second value...also SHARE option from camera is not working..
  14. W1578073507533
    W1578073507533 , Mar 24, 2021 :
    when it'll be released? any idea,and also my play store's upper 3 lines of side bar suddenly disappeared.. since 3-4 days.. [e]1f631[/e]
  15. suneelkumar206
    Eclair Mar 24, 2021
    suneelkumar206 , Mar 24, 2021 :
    Anyone facing notification issue??
    Like no notification in notification panel just notification dots over the apps
  16. Y1577094227950
  17. MoHiTsOoD,
    MoHiTsOoD, , via OnePlus 7T , Mar 24, 2021 :
    I think the wrongly pushed beta 5 instead of stable its not kinda look like stable.
    Are guys going launch a new series? Like first there will be be beta and then stable , then ULTRA PRO MAX STABLE🤭😂😂
    THANKS
    NEVERSETTLE🤭
  18. Uchiha Hunter
    Eclair Mar 24, 2021
    Uchiha Hunter , via OnePlus 7T , Mar 24, 2021 :
    Battery usage data is not being resetting at 90%... Now I have to charge the phone upto 100% . What type idiotic feature is this....?
