509
OxygenOS 11 for the OnePlus 7T Pro and OnePlus 7T
  1. V Rajender
    Gingerbread Mar 25, 2021
    V Rajender , Mar 25, 2021 :
    Powered By Oracle
    Connected
    Sajjid HuneriHi, my name is Sajjid Huneri. How may I help you?
    Sajjid HuneriHello, I hope you are doing well.
    V RajendharWhen get oneplus7t android 11 stable version
    V RajendharSo many users received stable android 11 version
    Sajjid HuneriI completely understand your concern.
    Sajjid HuneriThe update has been temporarily paused to ensure a smooth user experience, due to some bugs have been detected. We are now trying our best to investigate and will release an updated build ASAP in the near future.
    Sajjid HuneriUsers who have installed the previous version can get the issues fixed through the later version updates. Thank you very much for your patience.
    Sajjid HuneriJust to ensure we are connected on this chat, I request you to respond.
    V RajendharWhy paused
    V RajendharWhat's the reason so many users get notification
    Sajjid Huneri Due to some bugs have been detected. We are now trying our best to investigate and will release an updated build as soon as possible.
    Sajjid HuneriNot to worry, once everything get fixed the updated version will be released.
    tejasb93 and nonseth like this.
  2. JvdBeemt
    Ice Cream Sandwich Mar 25, 2021
    JvdBeemt , via OnePlus 7T , Mar 25, 2021 :
    Have you looked at the security settings for the app.
    Privacy settings for Android 11 changed quit a bit.
    Maybe there is a relation. Try setting location to always on for the camera app i.g.
    You never can tell 😀
  3. MisAnk
    Froyo Mar 25, 2021
    MisAnk , via OnePlus 7T , Mar 25, 2021 :
    I always do a hard reset after any major update, and my friends also did the same. We all installed it just after the announcement and did same thing.
    nonseth likes this.
  4. W1561898984022
    Donut Mar 25, 2021
  5. BunnyMunnu
    BunnyMunnu , via OnePlus 7T , Mar 25, 2021 :
    Ok do me a favor plz.
    https://drive.google.com/file/d/1-GNKs4qfd9CyOaL4LcjLJcn2V5iQ_Plk/view?usp=drivesdk
    Install this app. This is a paid music player app that I use from many yrs. Install it, open and allow all asked permissions. Clear the app in recents and open the app after a few minutes. Tell me what u see, the app opened or just a blank screen
    And also tell me the steps how did u installed and done the hard reset
  6. HarshaKasi7
    HarshaKasi7 , Mar 25, 2021 :
    Hey,
    I think the current stable is a mirror of OOS 11 Beta 1, but you're on beta 4. So, you'll have to downgrade to OOS 10 stable first and then update.
    Don't forget to backup and factory reset after updating.
  7. MisAnk
    Froyo Mar 25, 2021
  8. BunnyMunnu
  9. MisAnk
    Froyo Mar 25, 2021
    Not letting me download
  10. BunnyMunnu
  11. W1579682600360
    Donut Mar 25, 2021
  12. Deep_vachhani
    Donut Mar 25, 2021
  13. Hrvoje_B
    Eclair Mar 25, 2021
    Hrvoje_B , Mar 25, 2021 :
    Installed successfully on HD1900 Global version by Oxygen Updater, everything is working perfectly at the moment, even the camera has no problems at all. No overheating...
  14. MisAnk
    Froyo Mar 25, 2021
    Yup, it's not working... clearing cache is required everytime we open this app, as of now
  15. L1573652989021
    Cupcake Mar 25, 2021
  16. L1573652989021
  17. JvdBeemt
    Got a 1903 with EU version software as well.
    And mine works fine after the update.
    New Ui look and feel is also a lot more consistant, but it takes some getting used to.
    Guess some people will hate it no doubt.
    There are those who can't stand change, but me I'm totaly oke whith it.
    If you get it check the security settings for your apps.
    If you don't give the weather app location permission always i.g. you end up with a yellow exclamation sign on the shelf
    This is due to the way it works. Weather on the shelf usses the google weather app but it is not a standard widget. So it is seen as acces with app not opened.
    If the app is set for wheater on your pressent location. If you only select a city it might be fine, but have not tried that
    rabidhamster likes this.
  18. BunnyMunnu
    Yep, due to that bug, a weird thing is happening in between the quick settings and notification shade
    When I try to expand the notification shade, I am seeing this bug. After opening the notification shade, it's not showing anything there. And also again when I'm trying to minimize, the same bug appears
  19. BunnyMunnu
  20. SharanPrasad
