510
OxygenOS 11 for the OnePlus 7T Pro and OnePlus 7T
  1. Aaron2017
    KitKat Mar 25, 2021
    Aaron2017 , Mar 25, 2021 :
    Give it a 3 or 4 charging cycles, this is normal after a major update, it needs time to settle in
  2. C1578298288734
    Cupcake Mar 25, 2021
  3. ImSushant@
    Froyo Mar 25, 2021
    ImSushant@ , via OnePlus 7T , Mar 25, 2021 :
    Let me try
  4. ghostofcain
    Marshmallow Mar 25, 2021
    ghostofcain , Mar 25, 2021 :
    Android updates, especially major versions, require some optimisation after installation this normal results in an increased battery drain and sometimes increased operating temperatures for 2-3 charge cycles. This is completely normal and should resolve itself in a couple of days.
    parulavin likes this.
  5. ImSushant@
    Froyo Mar 25, 2021
    G1593235237703 likes this.
  6. Oksygen
    Gingerbread Mar 25, 2021
  7. REZIEL
  8. Movalis
    Movalis , Mar 25, 2021 :
    it says allow when using, there is unfortunately no option to always on...its more strange because it seems that only second value is odd...for example lcoation is 64" 4272", and its always the same no matter where I am.
  9. Mukul6902
    Froyo Mar 25, 2021
    Mukul6902 , via OnePlus 7T , Mar 25, 2021 :
    phone's working smooth battery life slightly less than os 10 on normal usage
  10. ImSushant@
    Froyo Mar 25, 2021
  11. UsmanHaider
    UsmanHaider , via OnePlus 7T , Mar 25, 2021 :
    Mine also disabled after and xanvas feature is also not showing in customization for me is it showing on your device ??
  12. Sam197
    Ice Cream Sandwich Mar 25, 2021
  13. BajanMax
    Eclair Mar 25, 2021
    BajanMax , via OnePlus 7T , Mar 25, 2021 :
    Give a few charging cycles. If you are noticing any other stutters you might want to factory reset. I had a few and after the reset, the phone works perfectly
  14. su00n
  15. Alex1681
    Alex1681 , via OnePlus 7T , Mar 25, 2021 :
    I have a global 7T I can't tell anything wrong....I got the OTA yesterday
    So far camera ...all apps and gaming is running smoothly
    Just rebooted and clear cache... everything good
  16. MehediiiHasan
    MehediiiHasan , via OnePlus 7T , Mar 25, 2021 :
    No😞😞😞
  17. Rohit@2911
    Donut Mar 25, 2021
  18. HarshaKasi7
    HarshaKasi7 , Mar 25, 2021 :
    Mate, it's already pinned as the top comment.
    AOD is still in beta testing. Apparently, it'll be incorporated into stable in the month of April.
    Peace 🕊️
    Aaron2017 likes this.
  19. KIRAN@13
    Donut Mar 25, 2021
  20. L1577420140745
    Eclair Mar 25, 2021
    L1577420140745 , Mar 25, 2021 :
    My feedback for this one is positive, at least on my HD1900 GLOBAL the update works perfectly, I even installed the Eu variant first than the global one and it worked the same, I don't have any problems with the camera, performance or a too notorious drain of the battery. I wonder why this update doesn't work correctly for other people, considering the fact that we all have the same phone, maybe it's something related to the model, I've seen some people with the HD1903 model (Probably EU) having a lot of issues. I hope oneplus team can fix the update for those models too
    techsteppler and nonseth like this.
