509
OxygenOS 11 for the OnePlus 7T Pro and OnePlus 7T
  1. Jagdesh.umapathy
    Cupcake Mar 25, 2021
  2. G_neelesh_kumar_JUOI
  3. REZIEL
    REZIEL , via OnePlus 7T Pro , Mar 25, 2021 :
    Thanks
  4. Amandeep_8129
    Froyo Mar 25, 2021
    Amandeep_8129 , via OnePlus 7T , Mar 25, 2021 :
    The update is so bad. Android 11 chat bubble feature is not working for whatsapp!!! I have even allowed all settings for chat bubble... Still not working... OnePlus you are not focusing on optimising features... Like just see this screenshot and see the buttons placement and whatsapp icon... Please fix this bug.
  5. geoxar
    Honeycomb Mar 25, 2021
    geoxar , via OnePlus 8 Pro , Mar 25, 2021 :
    Had this issue too the first time I have flashed the zip, managed to login with the Google account instead and then did a hard reset. The issue was gone afterwards.
  6. nonseth
    Donut Mar 25, 2021
  7. nonseth
    Donut Mar 25, 2021
  8. amitexe786
    Gingerbread Mar 25, 2021
    sree1906 likes this.
  9. ghostofcain
    Marshmallow Mar 25, 2021
    ghostofcain , Mar 25, 2021 :
    You haven't READ the thread, why?
  10. Ocean Fong
    Froyo Mar 25, 2021
    Ocean Fong , via OnePlus 7T Pro , Mar 25, 2021 :
    I'm on A11 custom ROM and bubble doesn't work for WhatsApp here too, so maybe it's a WhatsApp problem
    Amandeep_8129 likes this.
  11. mdhubail
    Eclair Mar 25, 2021
  12. D1546014791334
    D1546014791334 , via OnePlus 7T , Mar 25, 2021 :
    Hi David, I live in Andhra Pradesh in india. I am using one plus 7T. I did not receive the update yet. Can u suggest the feasible date that the update is going to be in Andhra Pradesh.
  13. Deep_vachhani
    Donut Mar 25, 2021
  14. seven_minus
  15. kmshashank
    Froyo Mar 25, 2021
    kmshashank , via OnePlus 7T , Mar 25, 2021 :
    I updated now , no worries... Way smoother better than oxygen 10
    Didn't like
    1. Greyish color os kinda theme in dark mode
    2. Front cam has greater smoothening effect than before
    (Rear camera no quality reduction - wide , main and tele lenses)
    3. Stutter here n there while scrolling in ad filled web pages , but won't bother you but still noticeable.
    Rest I got to say
    1. No battery issues
    2. No extreme heat issues
    3. Smooth ui as good as oxygen 10
    Heating issue (slightly high) will be reduced after your usage is learnt ... I believe
    No APP CRASHES so far (except OnePlus messaging app during initial setup)
    Note :
    Hard reset and update, no issues
    Go BREAK SOME EGGS !!!
    Oxygen 11
  16. JvdBeemt
    Ice Cream Sandwich Mar 25, 2021
    JvdBeemt , Mar 25, 2021 :
    ITried to repoduce your error. It works fine on my 7T i can switch the views and loose nothing.
    Might be the widget you have active for your Mediaplayer.
    can you try it without the widget ?? you might get the controls in the message area then, just like AIMP player does ( thats the app I use.
    If so contact the developer of the music player because it is then very likely its his fault.
    Hope this helps
  17. Bankov
    kmshashank likes this.
  18. ghostofcain
  19. JvdBeemt
    JvdBeemt , via OnePlus 7T , Mar 25, 2021 :
    Forgot to insert the picture
  20. Figura89 , via OnePlus 7T Pro Haze Blue , Mar 25, 2021 :
    I just don't understand what's up with these so many issues. I have updated my phone 2 days ago through OnePlus Updater, and everything works nicely, the new design is beautiful, I never had a problem with the WiFi and camera either and I love how you can operate your music player/Spotify/video player etc in the notification bar. Thanks OP, I still love you 😄😄
    jim1024 and Amandeep_8129 like this.
