509
OxygenOS 11 for the OnePlus 7T Pro and OnePlus 7T
  1. goofnugg
    Cupcake Mar 26, 2021
    goofnugg , via OnePlus Community App , Mar 26, 2021 :
    I bought mine from T-Mobile. Not paid off yet.
  2. Sam197
    Jelly Bean Mar 26, 2021
    VigneshOnePlus15 likes this.
  3. Sam197
    Sam197 , via OnePlus 7T , Mar 26, 2021 :
    T-Mobile control when they release the update, otherwise if you don't want to wait for them as it takes forever sometimes you can use oxygen updater as you did
  4. SarinKoodali
    Donut Mar 26, 2021
    L1578845754168 likes this.
  5. goofnugg
    Hmm that's weird tmobile told me they don't handle software updates. They said OnePlus does. Oh well. Thx again I'm not going to lose sleep over it
  6. Aniketjoshi0510 , via OnePlus 7T Pro , Mar 26, 2021 :
    Try doing hard reset with wiping off cache too...I have same device but it's working as expected
  7. GaneshAkg
    Froyo Mar 26, 2021
  8. khanfurqan
    khanfurqan , via OnePlus 7T , Mar 26, 2021 :
    said:
    2)
    1616733996270.jpg said: above are the screen shots of geekbench Ist one is on stable oxygen os 10 and the second one is after the oxygen 11 stable update...
    G1593235237703 likes this.
  9. avinash_verma
    Gingerbread Mar 26, 2021
  10. sumitradevi
    sumitradevi , via OnePlus 7T , Mar 26, 2021 :
    Same problem my one Plus 7t
  11. Perhydrol
  12. anujkmehrotra
    Donut Mar 26, 2021
    anujkmehrotra , via OnePlus 7T , Mar 26, 2021 :
    After reviewing the many feedbacks from many users, I installed the update from Oxygen Updater because no official update available through system update.
    After update and reboot enabled developer option and reboot into recovery to clean cache not data and reboot.
    Changed font to Roboto as OP Slate font doesn't look good. said:
    But found battery drainage a bit. Fixed with advanced battery optimisation option to stop drainage.
    Also found problem in screen lock time-out during typing sometimes.
    Rest is fine and working good.
  13. V1599394430527
    Donut Mar 26, 2021
  14. Koragg
    limkuanpow likes this.
