510
OxygenOS 11 for the OnePlus 7T Pro and OnePlus 7T
  1. Sorbh_ , via OnePlus 7T Frosted Silver , Mar 26, 2021 :
    Frame drops during whatsapp +alert slider bug + bettery issue + some time phone becomes laggy + bettery icon circle not working + double tab to wake screen work even after close + network issue sometimes ... Too muchh bugs .. fix them asap
  2. Anzik
    Ice Cream Sandwich Mar 26, 2021
    Deactivated User likes this.
  3. bplesa
    Gingerbread Mar 26, 2021
    bplesa , Mar 26, 2021 :
    What are those so many bugs?
    Not trying to defend OP, they tend to issue updates with bugs, but reading through complains, none is a proper bug report.
    Nobody is syaing what model of OP7T are using, what version of FW they had before update, update method, etc.
    This thread is useless, good only for killing time and have a laugh.
    o_O
  4. Sumanth1771 and Nani@KKR like this.
  5. Aswin08
    Honeycomb Mar 26, 2021
    Aswin08 , via OnePlus 7T Glacier Blue , Mar 26, 2021 :
    OxygenOS 11 OnePlus 7T Release 1 Initial impressions :
    (Note : Dirty flashed over OOS10 build and Carried forward Magisk Root)
    Positives :
    1. No major issues which makes the build unusable.
    2. Not facing many issues earlier reported in this thread.
    3. Overall Fluid.
    4. One-hand in OnePlus apps is very handy. (Also like the Lockscreen UI and Notification UI Changes, But I had to use Substratum to get rid of Grey BG in UI with Black BG)
    5. Battery and SOT seems good. In my case it's better than what i got with OOS10. (Without reset)
    Critical Issues faced by me :
    1. Double Tap or Single Tap to wake rarely works. (Not recognised often)
    2. Double Tap to wake vibration Missing (Really frustrating)
    More issues (is these some kind of empty features to release the build sooner?):
    1. Horizon Light not working completely.
    2. Canvas Beta not working completely (useless feature anyway).
    3rd Party Issues :
    1. Netflix Progress bar never goes off on touch (Old workaround doesn't work)
    2. Dolby Atmos App compatibility broken. (Can't blame OnePlus completely, but they could have improved the functions in inbuilt Dolby especially for Speaker)
    3. 3rd Party Recovery data Decryption still broken.
    Disappointments :
    1. No improvement in Camera quality (Just gimmicks like social share added)
  6. Nani@KKR
    Donut Mar 26, 2021
    Nani@KKR , Mar 26, 2021 :
    no luck😤
  7. Sumanth1771 likes this.
  8. Olaobas
    Froyo Mar 26, 2021
    Olaobas , via OnePlus 7T , Mar 26, 2021 :
    So more than 24hrs after update, I noticed:
    - Battery drains faster
    - Battery charges a lil bit slower
    - When charging, waking up phone from ambient mode, the phone goes blank, so have to pull down notification and click on a notification so as to push phone into asking for password
    - Font isn't as small as OS10, even after switching to small
    - Brightness adjustment is better than OS10
    - Keyboard is better than the last OS10 update
    - Camera UI is interesting but the camera needs work
    - For everytime I restart the phone, I'd have to reset some apps
    - Notification groups together, so when there's a new notification from the same app, it pops up all the notification from that app (it can be overwhelming, I'd say this needs some work too)
    ... would drop more updates when noticed.
  9. Olaobas
    Froyo Mar 26, 2021
  10. Daniel_Skultety , via OnePlus 7T Pro , Mar 26, 2021 :
    Bugs:
    Android auto won't start by itself, I have to manually select usb storage/transfer (or something like that)
    App for translating whatsapp is not working at all
    Some apps tend to stop working or they are laggy
    Video focus is even slower than before, which makes it indoors unusable.
    Photo shutter is slow
    Deleting photos/videos in Google photo always ask to allow moving files to trash
    Jimbobcook likes this.
  11. Vishnudev_vdk
    Froyo Mar 26, 2021
  12. Jimbobcook
    Cupcake Mar 26, 2021
    Jimbobcook , Mar 26, 2021 :
    I have this as well on mine... Rather Annoying! Cannot seem to find anything to try, even putting the default setting to File Transfer etc doesn't do anything. Also set no battery optimisation for Android Auto and removed and re-paired the phone removing the Android 10 version I had on the car as well
  13. Sumanth1771
    Froyo Mar 26, 2021
    Rikki_017 likes this.
  14. Sam197
    Sam197 , via OnePlus 7T , Mar 26, 2021 :
    Welcome to 11 brother
    Olaobas likes this.
  15. KUMARSANGEETHA
  16. Vino2009
  17. SatishS07
    Eclair Mar 26, 2021
  18. ghostofcain
    Marshmallow Mar 26, 2021
    ghostofcain , Mar 26, 2021 :
    Are you talking connected AA? I don't have a infotainment screen in my mini, but AA itself starts fine when I connect to BT.
    No bugs to mention here, and I value battery life too much to ever use AOD.
    Why you didn't read the thread yet?
    accuphase likes this.
