509
OxygenOS 11 for the OnePlus 7T Pro and OnePlus 7T
  1. G_Kostja
    Froyo Mar 27, 2021
    G_Kostja , Mar 27, 2021 :
    The OxygenOS11 stable and beta 4 are offered at the same time. How does that fit together? Usually the stable version is released after the last beta. Or have I thought incorrectly about that? This is a serious question. I'm not sure whether I should install the new version yet. :(
  2. Tareku
    Gingerbread Mar 27, 2021
    Tareku , via OnePlus 7T , Mar 27, 2021 :
    I am not too sure what everyone is complaining about.
    Camera works just fine, GeekBench score is higher in both single and multi core. Battery life is pretty good. None of my apps crashed/closed/lag. Did I get lucky ?
    Or did I just wait for the update to show and let my phone do its thing ? Probably the second one...
    Loving it so far.
    accuphase likes this.
  3. Tareku
    Beta and Stable are 2 different paths that run at the same time.
    Compare it to windows' insider program. Same thing here. Beta is just experimental features that stable will get later or never.
    G_Kostja likes this.
  4. Donatod87
    Froyo Mar 27, 2021
    Donatod87 , via OnePlus 7T , Mar 27, 2021 :
    Problems that my device has:
    1) with little light, the sensor turns off the ambient display and the double tap, when I turn on the light they return to work well, if I put back in the dark they no longer work;
    2) I noticed that the battery drains faster when I use the phone, when I do not use it I have no sudden drops
    I have the stable version with Oneplus 7t
    I am not at all satisfied with the work done!
    Instead of inserting stupid functions (such as Canvas) They had to test well and solve these serious problems!
    Now we are at fruit, Oneplus is like other brands that thinks only of money!
    SushChan130397 and amitexe786 like this.
  5. johnsema
    Froyo Mar 27, 2021
    johnsema , via OnePlus 7T , Mar 27, 2021 :
    No problem here!😬
    Oxygen os 11 works great on my 7T!
  6. johnsema
    Froyo Mar 27, 2021
    Install it, it works fine!👍
  7. Pratip77
    Donut Mar 27, 2021
  8. amitexe786
    amitexe786 , via OnePlus 7T , Mar 27, 2021 :
    Please check camera, switch between two lens.
  9. ghostofcain
    Marshmallow Mar 27, 2021
    ghostofcain , Mar 27, 2021 :
    Really, glad you told me as I was enjoying my slightly underwhelming but bug free update, and now I can be like all the rest and regret my update. What about it @johnsema , @JvdBeemt ,I imagine you too are regretting your update after reading this insightful post
  10. rahatkhanemon
    Cupcake Mar 27, 2021
    Lukasz2304 likes this.
  11. Bogdan8721
    Eclair Mar 27, 2021
    Bogdan8721 , via OnePlus 7T , Mar 27, 2021 :
    Does anyone know how to rollback to OS 10, i had stable version of OS10 and updated stable OS11 but is full of bugs.
    Can I rollback to 11 somehow? I tried to do it from the site but it says it cannot install it due it is older version.
  12. johnsema
    Froyo Mar 27, 2021
    Not really! Oxygen os 11 is working perfect on my 7T! No issues here!
    anujkmehrotra and Chris507 like this.
  13. Anwermusic
    mkzndr likes this.
  14. Only7o
    Eclair Mar 27, 2021
    Only7o , via OnePlus 7T Pro , Mar 27, 2021 :
    You have to understand that after carrying out such a large update as switching from 10 to 11, it is necessary to do a full wipe data and cache. Otherwise, it won't work well for you. For me there are no problems but I took a few more minutes to make it happen.
  15. Warlox4
    Eclair Mar 27, 2021
    Warlox4 , via OnePlus 7T , Mar 27, 2021 :
    After several days of use without any problem, I have started to have constant cuts in wifi. I have rebooted the system and the failure continues. Everything else works perfectly and the battery lasts well.
  16. Warlox4
    Eclair Mar 27, 2021
  17. tarkzy
    tarkzy , Mar 27, 2021 :
    Would you care to take look at the logcat l took and tell me the camera software isn't broken on my HD1903 ? Also seeing a catalogue of errors relating to issues that people are complaining about here.
    If your phone is working bug free then that's great for you others are not due this update.
    Sorry for rant but just sick of listening to the same 3 people in this forum claiming how good and how bug free this update is. When it's more than obvious there are big issues relating to one or more variants of the 7t.
    Also it's worth noting the logcat was taken from my phone after a clean install without root or any mods. If OnePlus can't see this then how they managed to release a rom in the first place is beyond me.
    geoxar, Drasm19 and Cecurado like this.
  18. JanLuck.Pincard
    Jelly Bean Mar 27, 2021
    JanLuck.Pincard , via OnePlus 7T , Mar 27, 2021 :
    Are te beta's not numbered consecutive within the lifetime of a version ?
    Then it would be completly logical to release a beta four.
    There only would be a restart in numbering if a 11.0.x ( where x is higher yhan zero ) would be released.
    So to me it does not sound as illogical as does to you.
    ghostofcain likes this.
  19. Aaron2017
    Lollipop Mar 27, 2021
    Aaron2017 , Mar 27, 2021 :
    download the rollback build you need from the open beta 1 thread
    after you've flashed that download the latest stable OOS10 build, the one on the official website is still latest OOS10 version.
    remove .jar at the end, it has to end with .zip
    copy it to your internal storage and install it via local upgrade.
    i did it myself so it works
    Sam197 likes this.
  20. rahatkhanemon
    rahatkhanemon , via OnePlus 7T , Mar 27, 2021 :
    Exact thing is happening with me also
    Warlox4 and andrequeiroz like this.
