510
OxygenOS 11 for the OnePlus 7T Pro and OnePlus 7T
  1. U1616911359715
    Cupcake Mar 28, 2021
  2. opojohnny
    Gingerbread Mar 28, 2021
    opojohnny , Mar 28, 2021 :
    You need to enable Developer options first. If not, go to Settings > About phone > Tap on "Build number" a few times until Developer option is unlocked.
    Then go to System > Developer options > Scroll down until you see "Smallest width" in "DRAWING" section, I changed to 470 dp (default is around 411 dp? i don't remember) which suits me well
    Udit2508 likes this.
  3. Udit2508
    Udit2508 , via OnePlus 7T , Mar 28, 2021 :
    Yes you are right it was 411 by default. I just wanted to confirm if the option i saw is right or not. Thanks for your detailed reply bro. Good day to you.
  4. tej.kaneria@gmai
  5. Aaron2017
    KitKat Mar 28, 2021
    Aaron2017 , Mar 28, 2021 :
    Do you charge with optimised charging enabled? If so, it might be because of that.
  6. Aaron2017
    KitKat Mar 28, 2021
    Yeah, same here. Definiteley because of OS11, it's the same on the 8 and 8 pro and it isn't like that in OS10
  7. shkshbz
    Donut Mar 28, 2021
  8. arunsagarsk
    arunsagarsk , via OnePlus 7T , Mar 28, 2021 :
    Been using oos11 for few days now. Everything seems to be running good exception being wifi. Wifi keeps on disconnecting and reconnecting.
    For me camera, battery, performance, and charging speed seems to be similar to oos10.
  9. johnsema
    Froyo Mar 28, 2021
  10. Rifazn
  11. OnePlusA11
    Froyo Mar 28, 2021
    OnePlusA11 , via OnePlus 7 Pro , Mar 28, 2021 :
    New bug :
    While playing music from any app.. even after closing the app song will continue but there is nothing in notification bar.. to pause or next nothing..
  12. OnePlusA11
    Froyo Mar 28, 2021
    Yesterday was having this issue.. just forgot once that WiFi and reboot .. then again enter the password.. and complete one charging cycle.. issue will be resolved.
    arunsagarsk likes this.
  13. Tw7064
    Tw7064 , via OnePlus 7T , Mar 28, 2021 :
    Does anyone else faces the issue with call recording ? I have noticed that if your automatic call recording is on it sometimes randomly skips to record the calls !! If anyone else facing the same issues please let me know if you found a work around.
  14. OnePlusA11
    Froyo Mar 28, 2021
  15. Aswin08
    Honeycomb Mar 28, 2021
    Aswin08 , Mar 28, 2021 :
    *Added battery impression too after 2 days of usage.
  16. OnePlusA11
    Froyo Mar 28, 2021
    Yess..411 was default.. but need to change it for matching with Android 10
  17. arunsagarsk
    Thank u. Will try it.
    OnePlusA11 likes this.
  18. Rifazn
  19. OnePlusA11
    Froyo Mar 28, 2021
