510
OxygenOS 11 for the OnePlus 7T Pro and OnePlus 7T
  1. Tricolour
    Froyo Mar 30, 2021
    Tricolour , via OnePlus 7T , Mar 30, 2021 :
    Updated through Oxygen Updater app. Not facing any camera problem. Battery draining little bit fast compared to android 10 but that is not a major issue and after every update battery takes couple of days to get normal. After update the drainage was high but now it has lowered. Heating issue was seen immediately after update but now after couple of days it is very less noticeable.
  2. stormshadow.1104
    Cupcake Mar 30, 2021
  3. Rishi317
    Gingerbread Mar 30, 2021
    Rishi317 , via OnePlus 7T , Mar 30, 2021 :
    Delete fingerprint data and add again properly
    C1533728852262 likes this.
  4. Damir Ilieski , via OnePlus 7T Pro , Mar 30, 2021 :
    This worked great thank you
    Maddog241 likes this.
  5. Abhishek_pv
    Donut Mar 30, 2021
    Damir Ilieski likes this.
  6. Vikas Sharma 7T
    Vikas Sharma 7T , Mar 30, 2021 :
    Personally, I really like the gaming performance in android 11 compared to android 10. Even is Haptic feedback in pubg is working great in android 11.
  7. Damir Ilieski , via OnePlus 7T Pro , Mar 30, 2021 :
    Agree same my side sometimes need to close the game to make it work better. no heating my side
  8. C1533728852262
  9. Abhishek_pv
    Donut Mar 30, 2021
    Abhishek_pv , via OnePlus 7T Pro , Mar 30, 2021 :
    And funny part is, if the battery falls below 15%, the whole frame is lagging while playing. I can't believe from a company who showed us benchmarking in software fluidity and it hurts!
    FariGzz and Damir Ilieski like this.
  10. Z1611314562403
    Z1611314562403 , Mar 30, 2021 :
    Hello everyone. If I upgrade from stable 11 to 4 beta, will the battery life improve? Now it is impossible to play games, heating up to 40 C, and the battery lasts for a maximum of 5 hours of screen operation, including 1 hour in the game.
    Mukul6902 likes this.
  11. ghostofcain
    Marshmallow Mar 30, 2021
    ghostofcain , Mar 30, 2021 :
    Ok, so why haven't you flashed the rom zip or used oxygen updater then?
    Probably best asking in the OB4 thread.
  12. apurvpandey0308
    Froyo Mar 30, 2021
  13. Z1611314562403
    Ok, I do
  14. O1574873005704
    O1574873005704 , Mar 30, 2021 :
    Because I don't know how to do that, that's why I was asking that can you get it just by updating the device, but obviously it tells me that I have the latest version available. I'm just wondering how did they test this update before they put it out
  15. Aaron2017
    KitKat Mar 30, 2021
    Aaron2017 , Mar 30, 2021 :
    Easiest way is the Oxygen updater app, it explains you the steps after you download the update. But you might want to read up on some of the problems other users are having, don't know what device you have but some are having serious problems
  16. Mukul6902
    Froyo Mar 30, 2021
    Mukul6902 , via OnePlus 7T , Mar 30, 2021 :
    experiencing the same issue bro mine reaches upto 42°
    aadhityan006 likes this.
  17. utkarsh_14
  18. O1574873005704
    I have 7t and I am aware of the problems. I'm just curious what went wrong with the update (other than camera) after couple months of fixing it
  19. Y1617098428506
