509
OxygenOS 11 for the OnePlus 7T Pro and OnePlus 7T
  1. danyboy1234
    Honeycomb Apr 14, 2021
  2. AndroidManiac
    AndroidManiac , via OnePlus 7T , Apr 14, 2021 :
    Sadly, there are not any customs ROMs available due to the encryption in the 7T that probably won't ever be fixed........... So, yeah, sadly it's not likely to have a very "pure" Andriod (Pixel like ) experience unless the manufacturer provides the Andriod "flavour" that the user prefers. I , for one, used the best custom ROM on my Samsung galaxy S7 - which made that device fast and slimmed completely down from all the Google and Samsung bloatware (that I still suffer from with this OnePlus Device). But, the point was that some very talented and generous ROM creators maintained the updates and patches regularly and readily.... Even if just security patches.
  3. T1584205074152
    Cupcake Apr 14, 2021
    Damodar Reddy7 likes this.
  4. AndroidManiac
    I thought I was just a monkey mashing away at a keyboard but what do I know....
  5. AndrewWanjohi
    AndrewWanjohi , via OnePlus 7T Pro , Apr 14, 2021 :
    My gaming experience has been bad since the roll out of OxygenOS 11. I keep getting the reconnecting icon in Call of Duty Mobile anytime I use WiFi and even when I use my local provider, the game doesn't run as smooth as before. I know it's the phone with a problem cause I tried using the Samsung S21 Ultra and the game is very smooth. This is very discouraging! Please fix it.
  6. C1581000248283
  7. AndroidManiac
    Source that states improved battery from 10 to 11 please? Thanks
  8. Sam197
    Jelly Bean Apr 14, 2021
    Sam197 , via OnePlus 7T , Apr 14, 2021 :
    Can you give the phone a few cycles to settle down.
    If you downloaded recently,give sometime
  9. Nixios
    Nixios , via OnePlus 7T Pro , Apr 14, 2021 :
    It has been a couple of weeks already....
  10. K_Kuldeep_Singh_yKcx
    Eclair Apr 14, 2021
  11. Sam197
    Oh,I see,it's suckes when you face something like that..
    Would you able to do another factory reset,I know you have done already but ,give it another try,but this time don't install all the apps in your account,just install the system,then take it one by one.
    You never know,,,,,
  12. nadeemzfr
  13. Damodar Reddy7 likes this.
  14. Buvaneshbhuvii
  15. devourerOfBits80
    devourerOfBits80 , via OnePlus 7T Pro , Apr 14, 2021 :
    Hahahahaha... very funny. 😁😁😁 They had time since October last year to release the stable version. They have over a half year of delay and you're trying to give them time? Are you serious mate? 🤣🤣🤣
  16. Mohan Reddy Y V M , via OnePlus 7T Glacier Blue , Apr 14, 2021 :
    What else we can do after expecting great software experience from oneplus? Just regretting regarding os upgrade. My first & last oneplus if this is the situation going forward. Only focused in new launches. 😔
  17. JvdBeemt
    Ice Cream Sandwich Apr 14, 2021
  18. ghostofcain
    Marshmallow Apr 14, 2021
    ghostofcain , Apr 14, 2021 :
    READING the thread, even the last couple of pages should suffice.
  19. Tanu_Su
    Donut Apr 14, 2021
    Tanu_Su , Apr 14, 2021 :
    Guys, I am making a list of bugs for Oneplus 7T Pro for Oxygen OS 11. Please continue to add on to this list if u find other bugs. If we maintain this list, it will be easier for oneplus devs to notice and fix.
    1. Device doesn't unlock from ambient display, even if correct fingerprint is given. It goes to lockscreen instead where fingerprint is needed 2nd time to unlock device.
    2. In status bar, network speed meter shows wrong bandwidth usage of connected to VPN.
    3. Wrong placement of ' do not disturb' icon on status bar. It should be left of volte and vpn icon.
    4. Poorer mobile data network utilisation due to older 'cubic' network congestion algorithm used in kernel. Samsung uses more advanced 'westwood+' and Google uses 'bbr'
