509
OxygenOS 11 for the OnePlus 7T Pro and OnePlus 7T
  1. ghostofcain
    Marshmallow May 11, 2021
    ghostofcain , May 11, 2021 :
    Try flashing the latest build, and READING and addressing your issues in the build thread, this thread is for 11.0.0
    https://forums.oneplus.com/threads/oxygenos-11-0-0-2-for-the-oneplus-7t-pro-and-oneplus-7t.1420069/
  2. mcleaver
    Donut May 11, 2021
    mcleaver , May 11, 2021 :
    Thanks, but that difference is not obvious. And most people have updated when offered and not as beta nerds. Only the 11.0.0.2 had been rolled out here.
  3. ghostofcain
    MOST users discuss issues in the latest build in the latest build thread, the only people you'll encounter posting in a deprecated thread, are those marooned on the old build, or confused users who don't understand what's going.
    mcleaver likes this.
  4. Mellema
    Cupcake May 11, 2021
  5. ghostofcain
  6. Mellema
  7. Edward_
    Ice Cream Sandwich May 12, 2021
    Edward_ , May 12, 2021 :
    How can I dismiss the notifications demanding that I install OOS11?
    It's a disgraceful screw up by one plus and this will be my last phone from them. It's a brilliant device and I don't want to ruin it.
  8. Mellema
    Cupcake May 14, 2021
    Mellema , May 14, 2021 :
    Turn off automatically download update. And in developer options automatically install updates. Then just open system update en close it then the message should disappear
    Edward_ likes this.
  9. GGanesh
    Donut May 15, 2021
  10. ghostofcain
    Marshmallow May 15, 2021
    ghostofcain , May 15, 2021 :
    This bulld has already been superseded by 11.0.0.2 try that and see if any of the issues have been solved.
  11. _Hari_Priya_ , via OnePlus 7T Glacier Blue , May 18, 2021 :
    Well In dark it's good but in light mode there is no option for thickness of letters fix that and after updating to android 11 why borders screen taking empty space and the icons are also so big doesn't fits I want to have a big screen with small icons with out any empty space fix thz things otherwise it's gud
  12. GGanesh
    Donut May 18, 2021
    GGanesh , via OnePlus 7T , May 18, 2021 :
    I am having the same OS build version, issues related to auto rotating and heating and other are started with new OS version 11.0.02
  13. ghostofcain
    Marshmallow May 18, 2021
    ghostofcain , May 18, 2021 :
    Well you're posting about them in the wrong thread then, my friend.
    GGanesh likes this.
  14. GGanesh
    Donut May 18, 2021
    Yeah I got that buddy, but what to do no one from OnePlus is not responding.
    I had a clash with one of the moderator, he is closing all the posts of mine saying it exists somewhere else.
    But actually I was unable to find the exact thing which relates to my queries.
  15. ghostofcain
    Marshmallow May 19, 2021
    ghostofcain , May 19, 2021 :
    You could try READING and posting in the thread for the build you ARE running, no need to open new threads when one already exists.
  16. GGanesh
    Donut May 19, 2021
  17. bathi_14
    Cupcake May 20, 2021
    bathi_14 , via OnePlus 7T , May 20, 2021 :
    But Oxygen rollout is not working after getting update. Phone is too slow to perform as comparison to earlier. Gallery takes time to open , OnePlus launcher do not work while using and many other things. It's like OnePlus is loosing the spot as a flagship phone. It's a disappointment after updating such a heavy file upgrade and waiting since last year. The results is really embarrassing..
  18. Manish0709
    Cupcake May 26, 2021
    Manish0709 , via OnePlus 7T , May 26, 2021 :
    right
  19. goodwrench1
    Donut May 26, 2021
  20. ghostofcain
    Marshmallow May 27, 2021
    ghostofcain , May 27, 2021 :
    Try the later builds, this build has been superseded by 11.0.0.2 and 11.0.1.1 they MIGHT fix your issues.
