451
OxygenOS 11 for the OnePlus 8 Pro and OnePlus 8
  1. Ozymandias_Osiris
    Honeycomb Oct 12, 2020
    Deactivated User likes this.
  2. Avishek2882
    Froyo Oct 12, 2020
    Avishek2882 , Oct 12, 2020 :
    can you check bro that on os 11 update we can still use photochrom using factory mode ?
    please check and tell me becasue I have rolled back my device to the old version and I always want to use photochrom for my phone.
    If it will not work on os 11 i am not going to upgrade my phone for no special effect.
  3. SteveCP
    Jelly Bean Oct 12, 2020
    SteveCP , via OnePlus 8 Pro , Oct 12, 2020 :
    Yes you can still use it via factory mode, I have it via termux.
  4. DoctrSuSE
    Donut Oct 12, 2020
    DoctrSuSE , Oct 12, 2020 :
    Is the beta track typically kept current on OnePlus devices? Security updates, code brought in line with stable, etc?
  5. Avishek2882
    Froyo Oct 12, 2020
    you mean to say works fine on os 11 right ?
  6. R.NIKHIL
    Eclair Oct 12, 2020
  7. J1588021824679
    Cupcake Oct 12, 2020
    J1588021824679 , via OnePlus 8 , Oct 12, 2020 :
    Kind of - I have audio but when I connect it says the unit already supports aptx (bluetooth notification in the top of the screen). I can't access settings for the headphones when connected - it just keeps crashing. I can access settings for the specific pair if not connected.
    Furthermore, if I adjust sound (equalizer) in a separate app, the sound guess metallic/scratchy and I have to set sound to standard and turn headphones off and then back on - they then work again.
    All this was not present in OS 10.
    PS: I have contacted OnePlus support with these findings.
  8. ianhandsup
    Gingerbread Oct 12, 2020
  9. SteveCP
    Avishek2882 likes this.
  10. Jona V.
  11. Sunilsudha
    Froyo Oct 12, 2020
    Akshay_0157 likes this.
  12. ankurbhoot
  13. Arun.16
  14. RajTalania
  15. Akshay_0157
  16. clemyjoy
    Donut Oct 12, 2020
  17. wordlife2010
  18. efks
    Ice Cream Sandwich Oct 12, 2020
    efks , Oct 12, 2020 :
    For huge upgrade needs folowing steps:
    1. Instal update turn off phone.
    2. Wipe full phone all media files photos and else(back up before everything)
    3. Boot phone setup and everything will work perfect 👍 no drain or heating . Today i thinking. always when i backed to android 10 i get everything good because its was clean install. good luck 🤗
  19. Akshay_0157 and cozzmat like this.
  20. MatteoCozzari
    MatteoCozzari , via OnePlus 6 Midnight Black , Oct 12, 2020 :
    but despite everything oneplus was very fast anyway. I would say an excellent sign of seriousness from the Oneplus!
    razorrahul and Akshay_0157 like this.
