450
OxygenOS 11 for the OnePlus 8 Pro and OnePlus 8
  1. valtras
    Cupcake Oct 12, 2020
  2. valtras
  3. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 12, 2020
  4. Himanshuchamoli
    Gingerbread Oct 12, 2020
    Himanshuchamoli , via OnePlus 8 , Oct 12, 2020 :
    Try full reset
  5. Himanshuchamoli
    You can use Oxygen updater app from playstore
    I did the same
  6. valtras
  7. Himanshuchamoli
    After major software update
    Full reset is recommended
    atleast try clearing cache from recovery mode
    RuuksterRules likes this.
  8. valtras
    valtras , via OnePlus 8 , Oct 12, 2020 :
    I know ,but after a big release also is coming a fix because is not possible to have all perfect. iOS the same. Maybe after I will
  9. Himanshuchamoli
    I am noticing higher ram usage after the update(all apps cleared from task bar).At OS10 usage was from 3.7-4.5GB
    Although os is smooth and battery life is at par with os10
  10. Himanshuchamoli
    Yes, I have done clean installation and its working same as was in OS10
  11. Amin.mousavi
  12. Knordor
    Eclair Oct 12, 2020
  13. V1597725054081
    V1597725054081 , Oct 12, 2020 :
    Hi,
    I am running o2 beta 2 on my 8 pro.
    I didn't got the ota update... Should I wait?
    I am trying to avoid factory reset...😭😭
  14. jmendozanunez
    Froyo Oct 12, 2020
    jmendozanunez , via OnePlus 8 Pro , Oct 12, 2020 :
    Update with app. Oxygen updater. Same thing as ota
  15. jmendozanunez
    Froyo Oct 12, 2020
    You will not get OTA to stable. This was mentioned as pre reqs when I installed beta in order to return to stable 11. U need to download link. And it will reset device.
  16. Swejuggalo
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 12, 2020 :
    From beta thread.
    Download full stable manually... Flash and get your device WIPED. You can't avoid that. And by using beta you agreed to it.
    Or stick with beta.... I'm waiting on beta 3 myself. Sticking with beta as long as I own the device.
  17. Rishabh_Singla
    Rishabh_Singla , via OnePlus 8 Pro , Oct 12, 2020 :
    I rolled back now what no oxygen os 11 update
