450
OxygenOS 11 for the OnePlus 8 Pro and OnePlus 8
  1. F_Tony_DeMartino_hjHI
    Ice Cream Sandwich Oct 13, 2020
    F_Tony_DeMartino_hjHI , via OnePlus 8 Pro , Oct 13, 2020 :
    No, that's not what I meant. The optimized charging kicks in (1/3 of the time... Maybe) at 80%. What I was saying is idk why they made the optimized charging cut off the charging module at 80% instead of 100%. There would be no issue. As it is now it cuts off at 80% and attempts to start charging again by the time you "usually" start using your device. The problem is... Sometimes you don't wake up at the same time everyday. I was pointing out the odd choice of the percentage cutoff for charging. Why isn't it just close off the module at 100%?
    Gautam2403 likes this.
  2. Rajat Gagarai
    Cupcake Oct 13, 2020
  3. F_Tony_DeMartino_hjHI
  4. F_Tony_DeMartino_hjHI
  5. efks
    efks , Oct 13, 2020 :
    True. Before i had oneplus 6t abuot 1.5years. Now op8pro and never NEVER no one apps did not crash . Dont know what they are doing. And battery goes perfect here per night lost 2 % in 8h sleep 🤗
  6. Plabon007
  7. efks
  8. Parthkansara
    Gingerbread Oct 13, 2020
  9. S1598709581332
  10. Parthkansara likes this.
  11. sahilpcs
    Froyo Oct 13, 2020
  12. sahilpcs likes this.
  13. F_Tony_DeMartino_hjHI
    That's exactly what it does. It's wonky though. I charge my phone at work and the optimized charging will stop the charge in the middle of the day for no reason.
    Anyway, good back and forth man. Good discussion.
    Deactivated User likes this.
  14. gmadmax07
    gmadmax07 , via OnePlus 8 Pro , Oct 13, 2020 :
    Upgraded from 10 to 11 through the update option was good but not perfect. I had some small issues here and there. But after I wiped it the phone works really great! A few minor issues like the weather dynamic icon is a bit slow to adjust. Generally, I like the animations and the smooth feeling. And I think first time to get an system upgrade before a new device launch.
  15. sahilpcs
    Froyo Oct 13, 2020
    sahilpcs , via OnePlus 8 , Oct 13, 2020 :
    It didn't work! Photos are in a Adobe Lightroom folder in Pictures folder.
    Pics by camera are visible. But from other cameras are causing issues.
  16. Mustafa3592
