450
OxygenOS 11 for the OnePlus 8 Pro and OnePlus 8
  1. fred1076
    Cupcake Oct 15, 2020
  2. Sinnaz0709
    Ice Cream Sandwich Oct 15, 2020
    Sinnaz0709 , via OnePlus 8 Pro Glacial Green , Oct 15, 2020 :
    So after making some changes my battery life seems to be a bit back to normal....this is what I did...
    1. Turned of the Print Scanning Service under bluetooth settings. Saw a bit of improvement...still had AoD on and the new live wallpaper.
    2. Turned off AoD. Battery life was improved even more amd I was getting back to the duration I had on OOS 10. However the New Live wallpaper was still in use. Some battery drain was still being experienced.
    3. Switched to one of the older live wall papers and my battery life normalized and almost back to where it was when on OOS 10.X.13.
    NO ADDITIONAL APPS WERE INSTALLED WHEN I UPGRADED from OOS10 to OOS11.... So I knew it wasn't an app.. There's definitely some tuning to be done on OOS11 and I really hope they sort this out in the near future.
    Those who didn't get OOS 11 please don't rush to install it and consider yourselves lucky...oos 10 was way cleaner and stable.
    G_Deepak_Jhala_tisZ likes this.
  3. U1580007062575
    Gingerbread Oct 15, 2020
  4. mrcampos91 , via OnePlus 8 Pro Onyx Black , Oct 15, 2020 :
    Have you installed the apk or did you received the update from the system as usual ? I'm from Portugal and I didn't get the update 🙄
  5. raneeshv85
  6. Harshil__07
    Harshil__07 , Oct 15, 2020 :
    Well unfortunately it's not an iphone
    If you wanna get the update on day one use oxygen os updater app
  7. E1602789288881
  8. FNunes
    Eclair Oct 15, 2020
    mrcampos91 likes this.
  9. valtras
  10. valtras
  11. mrcampos91 , via OnePlus 8 Pro Onyx Black , Oct 15, 2020 :
    I'll wait for the update in the system, I won't update trough the apk 👍 but it's strange some of you already had the update in system but others users (like me) don't 🤔
    FNunes likes this.
  12. Vinodmb likes this.
  13. Rafi7786
  14. MrJustRight1
    Eclair Oct 15, 2020
    MrJustRight1 , Oct 15, 2020 :
    Okay so my issue is after upgraded to 11, when i'm using WoWiFi and WoLte and i get call it doesn't show who is calling it says unknow doesn't even show which number is calling but when i turn both off then is working how it should. Anyone else with same issue 🤔
  15. Juniordoggy
    Juniordoggy , via OnePlus 8 Pro , Oct 15, 2020 :
    I updated to OxygenOS11 on my 8pro and I haven't had any issues so far. All the apps that I normally use work fine. Also the battery life seems to have improved
  16. doodle_away
    Eclair Oct 15, 2020
  17. NickCF
    Froyo Oct 15, 2020
  18. G_Richard_Fisher_lVIN , via OnePlus 8 Pro , Oct 15, 2020 :
    I'm the same , I ended up sticking with the beta OOS 11 , let me know when you get it in the UK so I can roll back and update [e]1f44d[/e]
    NickCF likes this.
  19. Terra1
    Terra1 , via OnePlus 8 Pro , Oct 15, 2020 :
    All good,
    As oneplus is such an easy device to install custom roms etc, seems that maybe giving people head aches......
    Yea bugs will always happen and most will get fixed over time.
    Great community for sure.....
