450
OxygenOS 11 for the OnePlus 8 Pro and OnePlus 8
  1. SteveCP
    Jelly Bean Oct 16, 2020
    SteveCP , via OnePlus 8 Pro , Oct 16, 2020 :
    That is up to T mobile, they release their own version of it.
    Haneshere50 likes this.
  2. Haneshere50
    Cupcake Oct 16, 2020
    SteveCP likes this.
  3. Shook_Zhou
    Froyo Oct 16, 2020
    Shook_Zhou , Oct 16, 2020 :
    How can I get the OTA from beta2 to official release? Still no OTA available from phone side. One Plus 8 Pro, USA version.
  4. W1574679881434
  5. SteveCP
    You won't receive stable OTA if you have OB2 your next OTA will be beta 3. Use the links posted in the thread to download the stable version and flash it over OB2 but you will wipe your data.
  6. Recmet
  7. RadioCommSpec , via OnePlus 8 T-Mobile , Oct 16, 2020 :
    I'm assuming that I must wait for T-Mobile to release Android 11 OTA, in the United States? I ask this because my system update screen has no gear in the upper right-hand corner.
    • Disregard!! I believe I found my answer earlier in the thread!!
    SteveCP likes this.
  8. tj10v
    Cupcake Oct 17, 2020
    RadioCommSpec likes this.
  9. G1590422680945
    Eclair Oct 17, 2020
  10. Pityakka
  11. MReyes69 , via OnePlus 8 Pro Ultramarine Blue , Oct 17, 2020 :
    That is odd since if you have a one plus 8 from T-Mobile it has to be locked. Only way you can run an unlocked version is if you bought your 8 or 8 pro directly from One Plus like I did. I have 8 pro on TMobile network that I bought directly from One Plus. So mine is unlocked and it's not dependent on TMobile for updates. That being said I also haven't received my OTA update yet.
  12. ftheriault
    Froyo Oct 17, 2020
  13. VishuN_09
  14. Tee_Eee_Bee
    Ice Cream Sandwich Oct 17, 2020
    Tee_Eee_Bee , Oct 17, 2020 :
    Some users have said that force stopping the messages app and clearing cache and data helps with issues
  15. YUVRAJP
  16. gauruv
    Gingerbread Oct 17, 2020
    gauruv , via OnePlus 8 , Oct 17, 2020 :
    U can either wait for OnePlus OTA update to reach your phone or sideload the update from Oxygen Updater app.
  17. VishuN_09
    VishuN_09 , via OnePlus 8 , Oct 17, 2020 :
    Will it be stable
  18. gauruv
    Yes, but even the stable update has quite a few bugs at the moment so proceed with caution.
  19. Yussuan
    Froyo Oct 17, 2020
    Yussuan , via OnePlus 8 Pro , Oct 17, 2020 :
    After updated to oxygen 11 among other bugs I just realized the weather app wont work properly, I mean wont detect my location unless I use a VPN, the GPS is working fine cuz the other apps detect my location, I used the OTA update, I have the IN11AA variant which is for North America, (not India), I was using the same variant before update to Oxygen 11 and everything was working properly, Im in China right now, any thoughts?
