450
OxygenOS 11 for the OnePlus 8 Pro and OnePlus 8
  1. shwongdi
    Honeycomb Oct 17, 2020
    shwongdi , via OnePlus 8 , Oct 17, 2020 :
    yes but if you take a full backup then you can restore everything. I did, works perfectly fine now.
  2. J1579018029223
    Gingerbread Oct 17, 2020
    J1579018029223 , via OnePlus 8 Pro , Oct 17, 2020 :
    Yes bro switch between Google Discover and One Plus Shelf as well as Scout Feature is missing and also black bar issue near camera cutout is still there have you noticed that
    SatishJana likes this.
  3. Sudarsen
    Donut Oct 17, 2020
  4. RupamShontu
    RupamShontu , via OnePlus 8 , Oct 17, 2020 :
    U will have to rename the file.. to be specific u will have to change the extension of the file.
  5. L1590734094984
    Cupcake Oct 17, 2020
    P1512576257525 likes this.
  6. Ozymandias_Osiris
    L1590734094984 likes this.
  7. Z1593797873038
  8. P1512576257525
    Eclair Oct 17, 2020
    RitikMittalRm and L1590734094984 like this.
  9. Anshuman1303
    Eclair Oct 17, 2020
  10. Sandeep.parida
    Donut Oct 17, 2020
    Sandeep.parida , via OnePlus 8 , Oct 17, 2020 :
    Oxygen 11 OTA update is out for the 8 series, but still has some bugs and glitches, hence the delay in roll out in India. I would like to know when will be the final OTA be reaching our region?
    RitikMittalRm likes this.
  11. cyberman_5145
    cyberman_5145 , via OnePlus 8 , Oct 17, 2020 :
    Anyone having issues with Bluetooth connectivity for earbuds / earpods on OnePlus 8 running official Android 11? My Bluetooth earpods work like a charm on other devices however doesn't give sound when connected with my OnePlus 8. How to fix this?
    TMDMOOSA likes this.
  12. Buddycool
    Eclair Oct 17, 2020
  13. T1599849640341
    Donut Oct 17, 2020
    T1599849640341 , via OnePlus 8 , Oct 17, 2020 :
    No update either. And I'm not a tech guy so I will not use other download link, I wait for the system to update. How long can it take you think? Kind Regards
    edit: I read some comments that not everything is working fine yet so I will do myself the pleasure and kindly be patience and wait. cheers
    EckoZ04 and Amrit7529 like this.
  14. cearap01
    karnaraja likes this.
  15. karnaraja
    Yussuan and official.suryakant like this.
  16. karnaraja
  17. shwongdi
    shwongdi , Oct 17, 2020 :
    Yeah I got the external link update but the whole OS is really buggy and lags a lot. Various app issues and minor annoying problems here and there. I downgraded back to OS10 tonight and its so much better tbh
  18. Karthikeyanq1178
    Karthikeyanq1178 , via OnePlus 8 Pro , Oct 17, 2020 :
    Oxygenos 11 gives a smooth experience, but the battery drain is high, on standby it at max loses 10% when I was using Oxygenos 10, after the 11 update it loses 15-17% at max, I hope OnePlus does something about it!
  19. NAFISA1625
  20. X1570717455902
