451
OxygenOS 11 for the OnePlus 8 Pro and OnePlus 8
  1. 222onetwo
    Honeycomb Oct 19, 2020
  2. Nitingup00
    Eclair Oct 19, 2020
    Nitingup00 , via OnePlus 8 Pro , Oct 19, 2020 :
    Worst update ever. Apps are crashing and not updating from play store battery life is ruined, games are lagging. Inconsistent UI and menus. Stutters all around the phone. My 8 Pro is like a mid range phone after this update. How can the developers be such ignorant and illiterate to release such a crappy update like this one. HATE THIS UPDATE, MY PHONE IS USELESS👎🏻👎🏻👎🏻👎🏻👎🏻
    M1595121762825 and shwongdi like this.
  3. KamilMag
    Cupcake Oct 19, 2020
    KamilMag , via OnePlus 8 Pro , Oct 19, 2020 :
    Just perform Factory reset via Recovery and it will be much better.
    Never seen good major update on android phone.
    After major update always perform factory reset via Recovery.
    Repeat it like mantra: "After major update always perform factory reset via Recovery"
    C'mon you can do it.
  4. Nitingup00
    Eclair Oct 19, 2020
    You kidding me right? After every update format my phone and loose all my data once every year😂😂
  5. Nitingup00
    Eclair Oct 19, 2020
    I've already cleared the cache from recovery mode but full wipe of phone is not possible for me. Hope this company understands not everyone purchases flagship phones just to get latest bugs with new updates
  6. KamilMag
    Also - if a man would believe in your whining comments - (s)he would never go to Oxygen 11, and would miss opportunity to has something better (as it is better than oxygen 10 on my phone).
    A man has just perform factory reset via recovery, and thats all. It's really easy...
  7. KamilMag
    Not after every update, but after every major update. Huge difference
  8. R1603134939047
    R1603134939047 , via OnePlus 8 , Oct 19, 2020 :
    Hi,
    Need help with a bug i found After updating to latest version.
    My clock is inverted at the display when my screen is off and i open it, and on the new ambient mode as well.
    Also when rolling till the end the notification bar.
    But main screen is fine.
    I guess it happens cause my phone's language is hebrew (i checked and its fine in english)..
    First picture - clock is revert. Its nineteen after midnight.
    Second picture - clock works fine.
    Ill Be thankfull if someone can help.
    Cheers!
  9. KamilMag
    This should be written: If you can't perform factory reset via recovery once a year, when there is a need - you should not use Android phones at all.
    I have never seen a major update which would not break something, and I used a couple of Androids, including Samsung flagships.
  10. Nitingup00
    Eclair Oct 19, 2020
    I think no one should update their phone to this crappy update. And bro "I CAN'T FACTORY RESET MY DEVICE". Why are you defending one plus if they can't provide a good update with no bugs?
  11. Nitingup00
    Eclair Oct 19, 2020
    I have also used Samsung devices and never have I ever faced any need to perform factory reset and I never defended Samsung for some minor bugs like you do for one plus. But afterall samsung fixed those minor issues too✌🏻
  12. Nitingup00
    Eclair Oct 19, 2020
    And I think you are the only person in the community who is not facing issue might be one plus themselves created a phone for you and Cael pei and Pete lau gave them to you. Cause the first post in this thread is itself of how to rollback to OOS10🤣🤣
  13. Nitingup00
    Eclair Oct 19, 2020
  14. KamilMag
    Not defending, but looking realistic. Developing software is not easy and software will always have bugs, at least untill AI will be able to write software for us. Major updates are even harder to implement because it may fail on so many possible ways, also caused by some crazy user configuration which no QA could possibly imagine. My experience shows that on major update phone has more bugs than it should and no matter what kind of fixes/workarounds I tried - always the factory reset was the best possible option to do.
    I just want to spare my time and that's why I am doing what? You know what I am doing.
    And so I advise you to not loose your time on waiting for magic unicorn fixing everything in on you phone and on writing countless number of whining comments here but to simply perform factory reset.
  15. KamilMag
    I can imagine scenarios where downgrade is the only option - for example of you are using app which is not capable of running on android 11 at all, and you can't live without this app.
    But is this o+ fault? No. Is this google fault? No. It's just fault of developer who created this app.
    Or ie update broke compatibility with the hardware which you are using, or something. Then it can be o+ or google fault - but do you really think they could possibly test everything? Like ie cheap unknown headphones? 🙂
    There should be always option to downgrade and its good its on first page.
  16. F1592849726492
  17. Tee_Eee_Bee
    Ice Cream Sandwich Oct 19, 2020
    Tee_Eee_Bee , Oct 19, 2020 :
    Some users have said that force stopping the messages app and clearing cache and data helps with issues
    M1603127307856 likes this.
  18. Pityakka
    Pityakka , via OnePlus 8 Pro , Oct 19, 2020 :
    After realising I will only receive beta updates after installing the Oxygen OS Open Beta, I want to roll back to a stable version to receive stable updates instead (if I've misunderstood how this works, please tell me).
    I see this message pop up when I try and do the rollback: said:
    Do I have to wait for a stable version of Oxygen OS 11 to be released first in order to roll back?
    Thanks
  19. Pityakka
