450
OxygenOS 11 for the OnePlus 8 Pro and OnePlus 8
  1. KnotReady
    Donut Oct 24, 2020
  2. Riobijoy
    Gingerbread Oct 24, 2020
  3. everkurt
    Honeycomb Oct 24, 2020
    everkurt , Oct 24, 2020 :
    Uninstall the gallery application's update.
    Up date again, it will work.
  4. ctljohnson1981
    Cupcake Oct 24, 2020
  5. slytherineon69
    Eclair Oct 24, 2020
    slytherineon69 , via OnePlus 8 , Oct 24, 2020 :
    Is Pubg running smoothly?
  6. U1581246311196
  7. N1518347353910
    N1518347353910 , via OnePlus 8 , Oct 24, 2020 :
    Hello bro..! Do u find 5G connectivity during mobile data in OS 11? Or else 4G only??
  8. P1589257175469
    P1589257175469 , via OnePlus 8 , Oct 24, 2020 :
    I'm having an issue, after the update, when I'm using third party wireless earbuds. I couldn't hear any thing from the earbuds when I'm using it after the update. And I also encounter an app crash when I tried to configure the earbuds thru the phone settings.
  9. Tinmor
    Eclair Oct 24, 2020
    Tinmor , Oct 24, 2020 :
    After about a week of usage, the Android 11 on my OnePlus 8 Pro works pretty good, I noticed the browser freeze bug is gone at least the whole week I didn't experience any freezes, on Android 10 it happens multiple times a day. I also like how fast all widgets loads up after reboot, on Android 10 it took few minutes, but on Android 11 it seems almost instantly which is pretty impressive. The battery life seems normal, I don't feel any battery drain problem like others, but I did wipe cache partition after update. I don't face any lags like others, the phone runs smoothly. I do face some weird bugs, but nothing major, there was once some reason my storage was unreadable, all app start to crash after launch, but once I reboot the phone it's back to normal and it haven't happen again. TrueCaller was suddenly start crashing after few days after update without reason, but once I cleared app cache and data, it's back to normal. I play Slotomania and it doesn't work on Android 11 was working fine on Android 10, it stuck on black screen after launch and everything is frozen until I press and hold the power button to force quite the app, I tried clear cache and data also uninstall/reinstall nothing helps. Gallery working fine and able to receive update from play store no problem, but in the app once you swipe all the way to the right it will ask to download extension, but once tap on download nothing happens and it will keep show that message evey time swipe to that section.
  10. Roobavignesh
  11. bikerboy360
    bikerboy360 , Oct 24, 2020 :
    The beta and 8T have it, so it should come soon enough.
  12. NigeMcc77
    NigeMcc77 , Oct 24, 2020 :
    I assume everyone complaining is submitting a bug report for their issues and not just venting on a forum page that in all honestly probably doesn't get read by the software developers all that often, if at all.
    Me personally, I haven't had any issues, installed via updater app and factory reset so a clean install.
    My only complaint is Android 11 now won't allow apps to overscan so I can no longer use my preferred navigation gesture app but apart from that it's all good.
    To anyone else in the UK just update via the Oxygen updater app if you don't want to wait for OTA but I would factory reset after to avoid the bugs that others seen to be having.
  13. G_Стаматов
    Eclair Oct 24, 2020
    G_Стаматов , Oct 24, 2020 :
    [QUOTE = "everkurt, post: 22276512, member: 987634"] Деинсталирайте актуализацията на приложението галерия.
    Отново актуална дата, ще работи. [/ QUOTE]
    Show step by step how to do it.
    abouaymane likes this.
  14. G_Стаматов
    Eclair Oct 24, 2020
    The gallery is not optimized. I read a lot of answers here, I did everything but it does not allow me to update the application. Give an idea how to fix it.
    Parthkansara likes this.
  15. shwongdi
    shwongdi , via OnePlus 8 , Oct 24, 2020 :
    Yeah the new font on this update is shit! Everything looks larger than usually and it's not uniform across apps.
