450
OxygenOS 11 for the OnePlus 8 Pro and OnePlus 8
  1. anmol.butta
    Froyo Oct 26, 2020
  2. Shivam__t1
    Froyo Oct 26, 2020
  3. ms_osage
    Cupcake Oct 26, 2020
  4. Manojkumar147
  5. Riobijoy
    Gingerbread Oct 26, 2020
  6. Jayesh_yadav
  7. UnamIndia
    UnamIndia , Oct 26, 2020 :
    I'm on OP 8 Beta 2, do I need to roll back to Oxygen OS 10 to get the Oxygen OS 11 stable update via OTA? I've been checking every day but my phone is not updating to Oxygen OS 11 stable build from beta.
  8. Tee_Eee_Bee
    Ice Cream Sandwich Oct 26, 2020
    Tee_Eee_Bee , Oct 26, 2020 :
    AFAIK, you can install the Stable A11 build manually over Beta 2, but it will wipe your data, so back everything up.
  9. UnamIndia
    Where do I get the link to download the stable build of Oxygen OS 11?
  10. SteveCP
    Jelly Bean Oct 26, 2020
    SteveCP , via OnePlus 8 Pro , Oct 26, 2020 :
    You will not receive 11 stable if you are on beta pathway as per the directions given on the beta thread, you will only receive beta OTAs. You can as mentioned manually flash 11 directly over beta 2 but it will wipe your data so make a back up.
  11. Tee_Eee_Bee
    You can download it via Oxygen Updater (3rd party app from the Play Store), or from links like these if you don't want to wait for the OTA to reach your phone.
    https://www.xda-developers.com/down...receive-stable-android-11-oxygenos-11-update/
    Download: Stable OxygenOS 11 update based on Android 11
    You can download the update and sideload it onto your phone. Download the appropriate package for your phone, go to Settings > System > System Updates, and then click on the top-right icon and select “Local Upgrade” option. From there, select the update package that you have downloaded and proceed.
    OnePlus 8
    OnePlus 8 Pro
    UnamIndia likes this.
  12. SteveCP
    Links are posted in the beta 2 thread post 1305 I believe.
  13. shivansh_5
    shivansh_5 , via OnePlus 8 Pro , Oct 26, 2020 :
    i received the oxygen os 11 update a day before yesterday and now when i am clicking on system updtaes option in settings it's addressing me a system is up to date ...please help
  14. G_Стаматов
    Eclair Oct 26, 2020
    G_Стаматов , Oct 26, 2020 :
    On the second day in the morning, the phone turns itself off when it removes them from the wireless charger. The dark theme changes with the morning itself and is made to be changed manually. The problems of this android do not stop. Pay attention !!!
  15. Bang Nguyen
  16. Riobijoy
  17. ROCKPRAVEENPK , via OnePlus 8 Pro Glacial Green , Oct 26, 2020 :
    As I have updated my OnePlus 8 pro with beta 11 the software is running good but one major issue for me is I can't able to connect with Bluetooth,as well it get connected but I can't able to here any songs and any other options kindly help me with it
    Thanking ,
    Rock PK
  18. A1603284964329
    Donut Oct 26, 2020
    A1603284964329 , Oct 26, 2020 :
    Updating my earlier comment from last week where I said battery drain is normal.. taking that back..from a steady 6hrs SOT on OOS10 im now at 4.5 to 5 with OOS11. Pretty lame. (No AOD)
  19. Shikhant
  20. razorrahul1
    razorrahul1 , via OnePlus 8 Pro , Oct 26, 2020 :
    Why the guys at OnePlus don't address the issues like big apps not installing and the half baked unfinished OOS 11 update 😌
    I've already reported the bugs but I didn't recieve any response
