450
OxygenOS 11 for the OnePlus 8 Pro and OnePlus 8
  1. J1544266516015 , via OnePlus 8 Pro , Oct 26, 2020 :
    Received the , stable global oxygen os 11.
    I have found an issue in camera.
    When shooting with 48mp lens the shutter button , goes round & round after clicking it.
    Its annoying & makes me hold the camera for the moment it stops going round & round.
    I want to know , do i require to , hold the , camera steady while the camera shutter button goes round & round.after clicking a picture.?
  2. brmbjn
    Gingerbread Oct 26, 2020
    brmbjn , Oct 26, 2020 :
    Settings - Wifi & Network - Sim & Network:
    Voice Call
    Messaging
    Mobile data
    must be in the same position.
    otherwise the RCS will not run.
    or if needed
    carrier service apk must be installed.
  3. Nick086
    Cupcake Oct 26, 2020
  4. I1600806610705
  5. I1600806610705
    Prashant2496 likes this.
  6. Riobijoy
    Riobijoy , via OnePlus 8 Interstellar Glow , Oct 26, 2020 :
    Same here also.....mine also disappeared....
    shivansh_5 likes this.
  7. Suddhu97
    Suddhu97 , via OnePlus 8 , Oct 26, 2020 :
    The update for oxygen 11 had come to my device.. But I hadn't downloaded it at that time.. Now when I go and try to download it in system updates, it doesn't show any available updates.. Can you please tell me why that could be the case
  8. Vechera
    Froyo Oct 26, 2020
    Vechera , via OnePlus 8 Pro , Oct 26, 2020 :
    Nothing, just traveling around (didn't even opened weather app by my self).
    but weather application received update and now looks OK.
  9. Riobijoy
    Till yesterday oxygen OS 11 is showing in system update but now it is not showing only thing that is showing that your system is up to date.
    shwongdi likes this.
  10. Z1594058942908
  11. Z1513875044438
    Z1513875044438 , via OnePlus 8 , Oct 26, 2020 :
    Moved from Hydrogen to Oxygen OS 11 via updater. App like Alipay, ******, taobao won't install. Tried Play store, APK files, showed message "Can't install alipay". Does anyone have the same problem?
  12. TomtommyP
    Froyo Oct 26, 2020
    TomtommyP , Oct 26, 2020 :
    I'm seeing a lot of random problems. I'm having none of them. I've tried to duplicate most of them without success. User error seems to be the problem in nearly ever case. I would say most of these problems are from restoring a backup that may restore some system settings that aren't compatible with 11.
    GaryWall likes this.
  13. Z1592317317006
    Z1592317317006 , via OnePlus 8 , Oct 26, 2020 :
    I had rec'd notification about the update and also seen the same of around 2250 mb in the update manager. But when I went to download it had disappeared to my surprise.
    When I run system update it is no more showing. What must be wrong?
  14. N1518347353910
    N1518347353910 , via OnePlus 8 , Oct 26, 2020 :
    When Did u received the update?
  15. GaryWall
    GaryWall , Oct 26, 2020 :
    You are very right about this! I cannot see a single problem with the OOS11 update. Even the battery life is very good, as long as you do not import all app settings from the old Android version and keep in mind that not all apps are optimized for the new Android 11 version yet. This is the price we must pay for being this early with a new Android version.
  16. shwongdi
    Honeycomb Oct 26, 2020
    shwongdi , via OnePlus 8 , Oct 26, 2020 :
    Yeah I noticed the same today. I can only hope that they've removed it to work on the bugs and issues. Would be great if they can push out a refurbished completely stable OS11 which is as smooth if not faster then OOS10.
  17. R1603718491882
    R1603718491882 , via OnePlus 8 , Oct 26, 2020 :
  18. Jamy23
    OnePlus Bug Hunter Staff Member Oct 26, 2020
    Jamy23 , Oct 26, 2020 :
    We would like to check this further and have got in touch with you via personal conversation for more details and would request you to respond the same.
    Regards,
    Jamy
  19. Jamy23
    We have got in touch with you for more details to get this issue resolved. Hope your coordination would be in place to get this resolved at the earliest.
    Regards,
    Jamy
  20. Jamy23
    For analyzing this better we would need more details to get this sorted out at the earliest. We've dropped you a personal message and hope you would get back to us at the earliest.
    Regards,
    Jamy
