450
OxygenOS 11 for the OnePlus 8 Pro and OnePlus 8
  1. SteveCP
    Jelly Bean Nov 8, 2020
    SteveCP , via OnePlus 8 Pro , Nov 8, 2020 :
    The update has been halted due to issues
    shwongdi likes this.
  2. admstudios
    Eclair Nov 8, 2020
    admstudios , via OnePlus 8 Pro , Nov 8, 2020 :
    Stay with the old OS for now until One plus company fix the many bugs that OS 11 has
    Kenjari likes this.
  3. Kenjari
    Donut Nov 8, 2020
    Kenjari , via OnePlus 8 Pro , Nov 8, 2020 :
    @admstudios
    Thanks for the advice. Not only am I enjoying this Oneplus experience, but I didn't know the 8pro was so premium. It's impressive.
    But it is sad that the company is struggling with the new OS11 update. I'm still a fan, but the daily notification of a new update is a tease. From what I read, 8T is having similar problems as well with the new update.
    Hopefully beta team provides good news soon.
  4. AodhaganW
    Eclair Nov 8, 2020
  5. Swejuggalo
    OnePlus 9 Series Expert Community Expert Nov 8, 2020
    AodhaganW likes this.
  6. SteveCP
    Second post says it is halted no other brief given
  7. SHAYAN_SOM
    Eclair Nov 8, 2020
    SHAYAN_SOM , via OnePlus 8 Pro , Nov 8, 2020 :
    how to return back to os 10!???
  8. Swejuggalo
  9. Ishan_Roy_Ch
    Cupcake Nov 9, 2020
  10. palhen1960
    Eclair Nov 9, 2020
    palhen1960 , via OnePlus 8 Pro , Nov 9, 2020 :
    I did initially. But I noticed that a lot of apps (153) were using background power by default. After sorting this out and a couple of full drains and recharges battery life is now very good. This was my issue so perhaps worth a look.
    O1598891354596 likes this.
  11. admstudios
    Eclair Nov 9, 2020
    admstudios , via OnePlus 8 Pro , Nov 9, 2020 :
    Yea i love the cellphone the 8 One Plus pro is a great experience to have on your hands , but i think the company would've wait a more bit for the realese of the OS11 update . But i know also as hard workers they are they Will fix it the 💯% accuracy 💪
    Kenjari likes this.
  12. Kenjari
    Donut Nov 9, 2020
    Kenjari , via OnePlus 8 Pro , Nov 9, 2020 :
    Absolutely!
  13. P1604504777897
    Cupcake Nov 9, 2020
    P1604504777897 , Nov 9, 2020 :
    Hello, is it normal that I still have not gotten the OxygenOS 11. I'm still on the 10 and the phone shows the message that the system is up to date?
    OXygebyOS 10.5.12.IN 11 BA
  14. Swejuggalo
    OnePlus 9 Series Expert Community Expert Nov 9, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Nov 9, 2020 :
    First 11 was halted. 11.0.1.1 is out but was temporary halted. But seems to be on it's way again. Normally rollout out to everyone in perhaps 2 weeks. Until then in a staged manner.
  15. Zubair.k
    Gingerbread Nov 11, 2020
    Starman and rachels42 like this.
  16. Alejandrofdez343
    Froyo Nov 11, 2020
    Alejandrofdez343 , Nov 11, 2020 :
    The battery is doing very well after five discharge cycles. This version is smooth and goes very well, the best of Android 11 so far.
    You only need to fix the green tint when dark mode is on and there is little light. And when you put the phone horizontally with YouTube and on Amazon Prime.
    And the error of inserting emojis in WhatsApp while typing, only the first line of text is shown, everything else does not appear unless you touch manually.
    Good work Oneplus team, keep it up, a little faster 👍🏼[​IMG]
    O1598891354596 and Nitingup00 like this.
  17. shwongdi
    Honeycomb Nov 11, 2020
    shwongdi , Nov 11, 2020 :
    What are the major differences you noticing bro? I'm finally thinking of shifting to OS11 as I'm still on 10, all these past issues and lags have made me very skeptical. Lemme know
    Zubair.k likes this.
  18. Zubair.k
    Zubair.k , via OnePlus 8 , Nov 11, 2020 :
    Will list the problems I faced in android 11 first update.
    1. Asphalt 9 wasn't getting installed.(fixed now)
    2. Web page freezing in Chrome sometimes (Still persist in 11.0.1.1)
    3. Screen usage timing on from 100% battery to 1% was only 5:30 hrs. (6:30 in 11.0.1.1)
    4. Whatsapp audio call were getting dropped after the screen was turned off.(fixed in 11.0.1.1). In whatsapp the emojis glitch still there.
    5. Glitches in certain apps in certain areas.(fixed in 11.0.1.1)
    6. File manager took almost 1 minute to load a large size folder of around 20gb (still persist in 10 , 11, and 11.0.1.1, they have never fixed it) According to android 11's new policy now other file managers doesn't have access to Android DATA and Obb folder. And only one file manager can be used at a time.
    7. Shutting down phone and Restarting took longer than Android 10. But it's a little faster now.
    Only known bug to me now is that. I put my phone on charging and after 10 minutes when pressed power button the screen wasn't turning on . Then it turned on after 7 seconds.
    Rest is working fine. It's stable now.
    And some third party apps which are crashing is not ONEPLUS'S fault. It's the app developers haven't updated the app for Android 11.
    Nitingup00 and shwongdi like this.
  19. shwongdi
    Sounds good so far, at least they are fixing some of the bad areas. I just updated to the previous 11 stable build a while back but still haven't gotten an update for this new ota yet. Hopefully I get it soon
