450
OxygenOS 11 for the OnePlus 8 Pro and OnePlus 8
  1. palhen1960
    Eclair Nov 15, 2020
    palhen1960 , via OnePlus 8 Pro , Nov 15, 2020 :
    You wait for oneplus ota. Or go on Oxygen Updater App on playstore. If you are on beta you need to downgrade to 10 first then update. If update from beta this will wipe your phone so make sure you back up first. Backup before is wise anyway.
    B3nno likes this.
  2. Rasool@1828 , via OnePlus 8 Glacial Green , Nov 16, 2020 :
    Data will be wiped ? U mean the pics , files , apps everything will be wiped?
  3. Rasool@1828 , via OnePlus 8 Glacial Green , Nov 16, 2020 :
    On clicking local upgrade it says move file into root directory..how to do that ?
  4. Tee_Eee_Bee
    Ice Cream Sandwich Nov 16, 2020
    Tee_Eee_Bee , Nov 16, 2020 :
    Root directory is the base level storage.
    If you are using file manager, tap on Storage at the base of the screen, then Internal storage.
    If you have already moved the file to this location and still can't see it when you try and update, make sure the filename ends in '.zip'. If there is a '.jar' file extension, remove it by renaming (delete the '.jar') the file in file manager.
    Any rollback to a previous version will wipe your data, so make sure you back everything up and copy the backup to a PC/Laptop or cloud storage.
  5. Fullframepix
    Gingerbread Nov 17, 2020
  6. Rebel Rouser
    Froyo Nov 17, 2020
    steve70882 likes this.
  7. Fullframepix
    Fullframepix , via OnePlus 8 Pro , Nov 17, 2020 :
    My first impressions are really great: no problems so far, the phone is still very reactive, the display is nicer with better fonts.
    The design look of the AOD is really cool as well 😎
    Very satisfied and impressed so far.
    It was worth the waiting for sure.
    palhen1960 likes this.
  8. Fullframepix
    Nice icons, stable launcher, new gestures, not bad at all.
    It really gave a new fresh look and update to my device!
    Let's see the battery drain but so far so good.
  9. admstudios
    Eclair Nov 18, 2020
    Kenjari likes this.
  10. mrlateach
    Cupcake Nov 19, 2020
  11. Swejuggalo
    OnePlus 9 Series Expert Community Expert Nov 19, 2020
  12. Z1602407409287
    Cupcake Nov 20, 2020
  13. Franz Maurer
    Donut Nov 24, 2020
    Franz Maurer , Nov 24, 2020 :
    What is version system ? oneplus 8 stable EU is oxygenos 10.5.11?
  14. AodhaganW
    Eclair Nov 24, 2020
    AodhaganW , via OnePlus 8 Pro , Nov 24, 2020 :
    The removal of permissions for the wide angle and telephoto lenses had caused big problems when using creative apps like FiLMiC Pro.
    This is hugely frustrating, I have reached out to the developers at FiLMiC and they responded the below statement confirming it is an issue with OnePlus.
    cls55 likes this.
  15. Neeraj.ku.yadav
    Froyo Nov 25, 2020
  16. SatishJana
    Eclair Nov 26, 2020
    SatishJana , via OnePlus 8 Pro , Nov 26, 2020 :
    Great OnePlus... Toggle switch is back
  17. Swejuggalo
    OnePlus 9 Series Expert Community Expert Nov 26, 2020
  18. FaroeKenfar
    Donut Nov 26, 2020
  19. NickCF
    Froyo Nov 26, 2020
    NickCF , via OnePlus 8 Pro , Nov 26, 2020 :
    Got new update as well. Too soon to say something but : seems really better ( didn't have major issues before): smoother, font and display better and smoother camera for me. No lag anymore between the camera and Google photo when I switch (Google photo is my default gallery I uninstalled OnePlus gallery).
    Let's see the battery improvements 😎
