450
OxygenOS 11 for the OnePlus 8 Pro and OnePlus 8
  1. SteveCP
    Jelly Bean Oct 10, 2020
    SteveCP , via OnePlus 8 Pro , Oct 10, 2020 :
    Not that I have noticed bit there are things in beta that aren't in stable
    Merriabdessalam likes this.
  2. abulsalam3
    Eclair Oct 10, 2020
  3. hugogirao
    Donut Oct 10, 2020
  4. Pikku1995
    Cupcake Oct 10, 2020
    Pikku1995 , via OnePlus 8 Pro , Oct 10, 2020 :
    i don't think samsung or Apple or anyone does that they open their beta and when stable is available they close what's the point running it alongside stable ?
  5. ftheriault
    Froyo Oct 10, 2020
  6. Merriabdessalam
    Merriabdessalam , via OnePlus 8 Pro , Oct 10, 2020 :
    Thanks buddy, then beta is better than stable?
  7. SteveCP
    Apple run beta alongside normal updates, I am on public beta 14.2 with apple
  8. sahilpcs
    Froyo Oct 10, 2020
    sahilpcs , via OnePlus 8 , Oct 10, 2020 :
    Also, phones in your default apps like Phone gallery and messages looks small as compared to what we see in notification panel.
    Font-size in default apps should be slightly larger.
    If I try adjusting the font size through the settings, making font size large, then font size in notification panel looks too big.
  9. SteveCP
    Beta will get things before stable but will have more issues than stable so it is wether you can deal.with the issues or not
  10. Pikku1995
    Apple also wipes your data when you switch from beta to stable ?
  11. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 10, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 10, 2020 :
    Pitch black has some downsides too. Black smear effects in low brightness. I don't think Google themselfs are in love with gray just in the name of love 😍
    If you haven't noticed...
    All Google apps. Gray like crazy.
    sahilpcs likes this.
  12. P1582298498951
  13. Ptaneja
    Donut Oct 10, 2020
    Ptaneja , via OnePlus 8 Pro , Oct 10, 2020 :
    Guys, I have updated and everything works flawless.
    Question is, can someone pls paste a link on how to reinstall latest release fresh from scratch ( fresh install instead of upgrade )? I mean just a reset from settings is enough ?
  14. SteveCP
    No you just delete the profile and rejoin the stable firmware but apple control their own firmware, OOS11 is an android reliant firmware so something's in the beta path may prevent this from.happening
  15. nusrat009
    Donut Oct 10, 2020
  16. yura17
    Donut Oct 10, 2020
  17. G_Kevin_HAMD
  18. AR1000
    Froyo Oct 10, 2020
    AR1000 , via OnePlus 8 Pro , Oct 10, 2020 :
    OnePlus you need to fix the Bluetooth. My head set no longer works. It states it's connected but no music. I use Spotify and it definitely is playing out of the phone speaker so the music is working. This is a big problem
  19. sahilpcs
    Froyo Oct 10, 2020
  20. Swejuggalo
    Different flavor. Different developer style. Oneplus can run some stuff in beta for months before stable gets it. And sometimes even futures for next phone.
    For me it's a very fun side of Oneplus.
    For some betas can be the versions inbetween stable versions. But here they are a path of their own. Parts of betas can be cherry picked to stable but stable is not directly based on x amount of betas.
