450
OxygenOS 11 for the OnePlus 8 Pro and OnePlus 8
  1. POIZ
    Froyo Oct 11, 2020
  2. Ozymandias_Osiris
    Honeycomb Oct 11, 2020
  3. Sinnaz0709
    Ice Cream Sandwich Oct 11, 2020
    Sinnaz0709 , via OnePlus 8 Pro Glacial Green , Oct 11, 2020 :
    Quick question . Is there anyway to prevent the AoD to stay center screen vs rotating ? Not sure if I missed it ....I have the preference of staying in one location....if not I can live with it was just wondering....I'm assuming it was meant to rotate to avoid screen burn or sum...
    ianhandsup likes this.
  4. Jzma
    Froyo Oct 11, 2020
    Jzma , via OnePlus 8 Pro , Oct 11, 2020 :
    I will transfer to Oxygen 11 when it be ready and clean. For now it's mess, HUUUUGE awful unreadable fonts, bugs in animation, awful battery drain in AoD and in general, grey instead of black dark mode, etc etc. I expect improvement and i get mid range experience with my Oneplus 8 pro. Never ever expect such miserable update from a trusted company like Oneplus.
    Fero9000 and Mudit@22 like this.
  5. trane5700
    Froyo Oct 11, 2020
    trane5700 , via OnePlus 8 , Oct 11, 2020 :
    Can you please add the option to turn off that creepy EIS for video in stock app? It's only add artifacts in low light. I need just toggle in camera app settings.
    1+8
  6. heartless28
    Gingerbread Oct 11, 2020
    heartless28 , via OnePlus 8 Pro , Oct 11, 2020 :
    tried everything.
    1. wipe cache
    2. hard reset
    3. used 1 sim only
    4. swap sim cards
    5. roll back to 10 and upgrade again to 11
    it will only work fine if i set the signal into 2G only.
    note: we have now 6 reports in our group with the same issue not only with the 8 pro but oneplus 8 as well. both IN2020 and IN2023 having the same issue.
    This issue was present in Beta 2.
  7. heartless28
    we have the same exact issue. btw may i know which network you are using?
  8. Reemie221
    Cupcake Oct 11, 2020
    Reemie221 , Oct 11, 2020 :
    I have the Open Beta? Would I receive the OTA notification or shall I take it back to the older version?
  9. NaiyerAsif
    NaiyerAsif , Oct 11, 2020 :
    So the update landed today and it is not total catastrophe I was expecting it to be. My only complaint is that if you provide an option to select a font, the same font should be applied on Notification and Lockscreen. But they both are coded to be on OnePlus Sans which looks pretty terrible (even more so from accessibility point of view, which was ironically the goal of new UI).
  10. Funk Wizard
    Moderator Moderator Oct 11, 2020
  11. Gillysixpence
    Gillysixpence , via OnePlus 8 , Oct 11, 2020 :
    When in recovery me & hubby both get the option to wipe data & cache but not just the cache. What does that option do as we don't want to factory reset. How do you just wipe the cache please?
  12. efks
    efks , Oct 11, 2020 :
    might be or will be 🤔 huge problems with google aps higher android system battery and google play services seems pixel phones have too draining ☝️😉
  13. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 11, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 11, 2020 :
    No... Beta gets beta updates. You have to manually download and install Stable. But that will wipe the phone. Everything was described in the beta threads. Betas will continue... I'm waiting on beta 3 myself.
    SteveCP likes this.
  14. SteveCP
    Jelly Bean Oct 11, 2020
    SteveCP , via OnePlus 8 Pro , Oct 11, 2020 :
    Why? It was released yesterday, it could take hours or weeks to roll out to your device, the 14th is the 8T announcement nothing to do with OOS11 now.
    Shivam000000001 likes this.
  15. F_Любомир_Ива
    Froyo Oct 11, 2020
    F_Любомир_Ива , Oct 11, 2020 :
    Welcome to the famous Oxygen OS experience mate! Something you won`t hear about in all the payed reviews on YouTube! They always release complete useless crap just to say that they are first and after that it takes months and months to bring the software anywhere near to being ok to be used. They ruined my 6t like that and I got rid of the phone 5 months after and most of the issues weren`t fixed... But this is what happens when the GREED kicks in and when you release 5 devices per year when you are not able to support eve one properly!
    ilCapitano91 likes this.
  16. SteveCP
    This OTA won't have the fix so it does not matter if people flash manual or wait for this OTA, I am guessing with the amount of issues some are facing though that a fix will be released soon via a new OTA
    Gillysixpence likes this.
  17. Shivam000000001 , via OnePlus 8 Interstellar Glow , Oct 11, 2020 :
    If this is so , i hope i also get the official update Asap , coz i haven't got yet, and i will not try from oxygen os updater app, rather i would wait
  18. Princevs2
    Princevs2 , via OnePlus 8 , Oct 11, 2020 :
    Pixel phones with android 11 has better battery backup as compared to android 10.
    You can check the comparison on youtube.
    Android 11 is the best but oxygen 11 is ugly!
    both Lookwise & performance wise.
  19. Louis Cochard
    Louis Cochard , via OnePlus 8 , Oct 11, 2020 :
    Hello,
    thanks for the OxygenOs 11 but I have two problems :
    CAMERA and FLASHLIGHT don't work with OS 11 Beta and also OS 11 Official
    I had no problem with OS 10.
    My phone : OnePlus 8 (IN2013).
    Thanks
    Fero9000 likes this.
  20. SteveCP
    Unfortunately the roll out can take a long time, some people only recently received the 10.5.13 update and that was released almost 2 months ago so you can wait for it to hit or update via one of the other methods.
