484
OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. SteveCP
    Jelly Bean Sep 16, 2020
  2. SteveCP
    SteveCP , via OnePlus 8 Pro Onyx Black , Sep 16, 2020 :
    The screen issues are nothing to do with the beta program, they existed for those with issues long before the beta was released. The same issues have plagued Samsung and iPhone with this type of screen.
  3. deepanka27 , via OnePlus 8 Pro Ultramarine Blue , Sep 16, 2020 :
    but previously I didn't face some issue....after installing it I am getting this type of issue.....so where from the problems coming??? please tell me either its a hardware problem or software?
  4. Aayush121dwivedi
    Cupcake Sep 16, 2020
  5. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 16, 2020 :
    From your description with stripes and hangs... Your stripes were all the way on the length or hight? Temporary?
    Sound more like hardware issue.
    And when it comes to devs/bughunters... Report all your issues via the feedback tool. You will rarely get any type of help or comments by OnePlus in a thread like this.
  6. deepanka27 , via OnePlus 8 Pro Ultramarine Blue , Sep 16, 2020 :
    Ok thanks a lot.....if it is the problem from hardware....then can I claim screen replacement under warrenty?
  7. AdithyaNair
    AdithyaNair , via OnePlus 8 , Sep 16, 2020 :
    Open beta 1 problems i faced:-
    1) They removed work life balance feature.
    2) Lock screen shows 24 hr format
    3) Chrome is not at all optimised for the displsy.
    4) Chrome gets stuck sometimes.
    5) Cursor is not at all visible in both dark and normal mode.
    6) Adaptive brightness is not working properly.
    7) Can't use more than 1 freeform window.
    8) There is a display issue with reading in Adobe Acrobat reader.
    9) Work Life Balance is not available.
    Many more on the way
    Please fix these and release a stable update.
  8. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 16, 2020 :
    Yes. If you get it confirmed to be a hardware issue it is a warranty errand.
    Only problem that might happen would be if the phone has triggered moisture detectors (those white squares turned pink/red). That would put the cost on you instead.
    deepanka27 likes this.
  9. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 16, 2020 :
    They didn't remove work-life. They mentioned that they haven't released Indian specific beta yet. Should come with beta 2
  10. VamsiKrishn
    Eclair Sep 16, 2020
  11. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 16, 2020 :
    Please report all bugs via the feedback tool with detailed information and screenshot examples when possible.
  12. Rajat0092
  13. SoniaB
    Nougat Head Moderator Sep 16, 2020
    gubro likes this.
  14. F.Y_Videos2001
    Eclair Sep 16, 2020
  15. deepanka27 , via OnePlus 8 Pro Ultramarine Blue , Sep 16, 2020 :
    ok.thanks for your information bro
  16. gubro
    KitKat Sep 16, 2020
    SoniaB likes this.
  17. deepanka27 , via OnePlus 8 Pro Ultramarine Blue , Sep 16, 2020 :
    yes it happened to me also....one plus's own apps couldnot be updated...rest 3 rd party apps are out of the topic....its better to go stable version or DP4
  18. brmbjn
    Gingerbread Sep 16, 2020
    brmbjn , Sep 16, 2020 :
    why ?
    this is just the first version, maybe we have to wait until 5 or 8 times the beta.
    try update from apkmirror
