482
OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. C1600314843833
    Cupcake Sep 17, 2020
  2. Jeji.George
    Eclair Sep 17, 2020
  3. evnsriram
    Eclair Sep 17, 2020
    evnsriram , via OnePlus 8 , Sep 17, 2020 :
    It would be an incremental update if you're already on OB 1. You can also flash complete rom if you would like to. Up to you.
  4. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 17, 2020 :
    Should not cause any issues if you flash full Indian rom over OB1. If you haven't installed OB1 yet you might as well wait on OB2 though.
  5. brmbjn
    Gingerbread Sep 17, 2020
    brmbjn , Sep 17, 2020 :
    what do you mean by OB2?
    is OB2 available?
  6. A1595350330445
  7. brmbjn
    beta version made for all users.
    it is not possible to make a beta version for each region.
    because it will be difficult to control it.
    gubro likes this.
  8. firoz3321
    Froyo Sep 17, 2020
    firoz3321 , via OnePlus 8 , Sep 17, 2020 :
    Hi i am from India and using 11 on oneplus 8 from many days. I personally haven't found huge concerns. Let me know what u want to know and i will check and update.
  9. Akhil.Hundekar
  10. brmbjn
    on my oneplus 8 pro
    not experiencing significant bugs.
  11. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 17, 2020 :
    You can wait on beta 2 if the Indian specific features are important to you.
    A1595350330445 likes this.
  12. gubro likes this.
  13. ianmolmanocha97
  14. A1595350330445
    A1595350330445 , via OnePlus 8 , Sep 17, 2020 :
    I have no specific features to say...would be thankful if you can let me know the features which are curtailed by this update-thank you
  15. brmbjn
  16. brmbjn
    yellow it is the official browser from oneplus
    while the blue browser from google. and the one with an orange dot maybe it's a parallel app.
  17. firoz3321
    Froyo Sep 17, 2020
    The only issue i observed is Battery icon is missing and i can't see the battery percentage at a glance, i have pull down the notification bar to see the battery status. I am rooted with magisk and all banking apps seem to work fine. No network issues with Airtel and VI networks.
