483
OxygenOS 11 Open Beta 1 for OnePlus 8 Series
  1. David Y.
    OxygenOS Staff Member Sep 9, 2020
    Stickied Post
  2. ZachThaMac92
    Cupcake Sep 9, 2020
    ZachThaMac92 , Sep 9, 2020 :
    How do I locally upgrade my software to this beta with the OnePlus 8 from sprint/TMobile? There is no button to push after I go to the system update screen..
    zwest1 and V1598904571496 like this.
  3. V1598904571496 , via OnePlus 8 T-Mobile , Sep 9, 2020 :
    I asked the same question earlier. No response.
  4. Azzlan786
    Eclair Sep 9, 2020
    Azzlan786 , via OnePlus 8 , Sep 9, 2020 :
    Updated and almost everything is working fine.
    The only issue I have encountered so far is that I can't trigger Google Assistant via the corner swipe gesture. said:
    Edit: Corner gesture for Google Assistant works in Gesture mode with bottom bar enabled. But doesn't work when bottom bar is disabled.
  5. TechZeek
    Cupcake Sep 9, 2020
    TechZeek , via OnePlus 8 Pro , Sep 9, 2020 :
    I have a OnePlus 8 pro I bought from the OnePlus site and use on T-Mobile. I have downloaded the proper update file and move it into internal storage a thousand times. Still does not show in updates to use. How may I fix this? Thanks in advance.
    zwest1 likes this.
  6. smithad150
    Cupcake Sep 9, 2020
  7. ZachThaMac92
    Cupcake Sep 9, 2020
    Yeah this isn't the first time I've asked this either. I haven't received a response from when they posted the last build either.
  8. Sharad ahlawat
    Cupcake Sep 9, 2020
  9. jmendozanunez
    Eclair Sep 9, 2020
    jmendozanunez , via OnePlus 8 Pro , Sep 9, 2020 :
    Not sure this beta works on tmo/sprint ... Verizon variants....but if does once u download rename remove .jar from file name go to settings update . Top right little gear select update locally
  10. V1598904571496 , via OnePlus 8 T-Mobile , Sep 9, 2020 :
    That's the thing, there is no gear in the top right. For me it's a search icon
  11. Dodol
    Eclair Sep 9, 2020
  12. Meowmixez98
    Eclair Sep 9, 2020
    Meowmixez98 , via OnePlus 8 Pro , Sep 9, 2020 :
    Okay I got it working. My initial impressions are mixed. I'm not a fan of the new font as it just looks bland but it does improve readability. It just isn't pretty to look at. The new font is just plain. I don't care for the default red accents and went with the older blue. I also think reducing the amount of toggles on the notification shade was a mistake.
    ianhandsup likes this.
  13. ZachThaMac92
    Cupcake Sep 9, 2020
    No gear button for me either, just the search button .
  14. krishnaE
    Froyo Sep 9, 2020
  15. ZachThaMac92
    Cupcake Sep 9, 2020
    And I have no clue as to why it wouldn't work with the TMobile version. As I was able to do manual updates with no problem on the 7t from tmobile
  16. jmendozanunez
    Eclair Sep 9, 2020
    Not sure! But I believe somehow u can convert your device to Global version . And leave behind carrier 🤮
    zwest1 likes this.
  17. Chendil
    Froyo Sep 9, 2020
  18. JoseReyes69
    Gingerbread Sep 9, 2020
    JoseReyes69 , Sep 9, 2020 :
    Motion wallpapers working for me, google pay is not
  19. Cervantes
    Lollipop Moderator Sep 9, 2020
    Cervantes , Sep 9, 2020 :
    Hola
    Por favor debes usar el idoma del hilo: escribir en ingles, si deseas escribir en español debes abrir un hilo
    una version beta es una version de prueba, en el primer posttienes informacion para reportar un error
    puedes revisar las reglas del foro
    https://forums.oneplus.com/threads/reglas-del-foro-actualizacion-mayo-2020.448019/
  20. ianhandsup likes this.
