437
OxygenOS 11 Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. HariZenith
    Cupcake Jan 26, 2021
  2. Artemus.
    Community Hero 2020 Jan 26, 2021
    Artemus. , Jan 26, 2021 :
    Not for a few weeks to a month or so, depending on how many bugs need to be fixed.
    HariZenith likes this.
  3. JVJ003
  4. akks
    KitKat Jan 26, 2021
    akks , Jan 26, 2021 :
    Usually one update a month. Can vary according to the need.
  5. ISMAIL SHAMEEM
    Eclair Jan 26, 2021
  6. Joemtz70
    Froyo Jan 26, 2021
    Joemtz70 , via OnePlus 7 Pro , Jan 26, 2021 :
    Finally got it installed but some issues or bugs whatever you wanna call it. When I receive a text message their pop up shows up in a bright white. In every message very annoying. And some of my blogs are all in white. Checked all my settings can't change it
  7. akks
    KitKat Jan 26, 2021
    Restart your phone once. Clear system cache
  8. akks
    KitKat Jan 26, 2021
    Was it there previously? If so, send feedback or report bug using feedback tool, as told in opening post.
    Also comment in 7T forum thread, instead
  9. ISMAIL SHAMEEM
    Eclair Jan 26, 2021
    ISMAIL SHAMEEM , via OnePlus 7T , Jan 26, 2021 :
    Yeah it was there in stable build
  10. Y1545594691536
    Y1545594691536 , Jan 26, 2021 :
    Why my oneplus 7 (Oxygen OS 11 beta Version) Starts recollecting my photos and videos every time i open the app. It took like 5 to10 seconds to load all photos and videos in the Gallary app to be able to see which is very annoying is there any solution for this ?
  11. akks
    KitKat Jan 26, 2021
    Read the opening post carefully
  12. gdsingh94
    Jelly Bean Jan 26, 2021
    gdsingh94 , Jan 26, 2021 :
    Because you didn't read the opening post properly before installing the update..
    Y1545594691536 likes this.
  13. akks
    KitKat Jan 26, 2021
    Ask in 7T forum thread. Can report feedback if needed
  14. TheStonk
    Gingerbread Jan 26, 2021
  15. Francisqin
  16. SUSMPATIL
  17. H1558975899794
  18. vinodvsuthar
  19. x_jayreghe_x
    Honeycomb Jan 26, 2021
    x_jayreghe_x , via OnePlus 7 , Jan 26, 2021 :
    Anyone else facing the issue where app notification does not get dismissed from notification panel even after opening the app?
  20. gdsingh94
    No you have to roll back to 10 stable and then you will get stable 11.. this process will wipe your data...
