435
OxygenOS 11 Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. srini0301
    Jelly Bean Jan 20, 2021
    srini0301 , Jan 20, 2021 :
    wcześniej był na wersji beta systemu operacyjnego.
  2. PatrykPredator
    Cupcake Jan 20, 2021
    PatrykPredator , Jan 20, 2021 :
    Aha, masz po aktualizacji do androida 11 po polsku?
  3. Tinglish
    Gingerbread Jan 20, 2021
    Tinglish , via OnePlus 7 Pro , Jan 20, 2021 :
    Hi I've updated this beta for my op 7 pro,and I've got to be honest I haven't seen any major bugs,there is a couple of things missing that I have on my 8t like Google feed and always on display,but this is a beta so should come with the stable version
    cavalry_r3b00t3d likes this.
  4. 1tseddy
    Froyo Jan 20, 2021
    Yunusrg likes this.
  5. SiddharthRaj
    Donut Jan 20, 2021
    damian_net likes this.
  6. Udai Sharma
  7. Tinglish
    Maybe it's just missing on the beta 🤷,I mean you can still tap the screen to see it like before, hopefully when The stable version comes out it will have it
  8. srini0301
    Czy chcesz zaktualizować system do Androida 11 beta bez utraty danych?
  9. rhyd1am
    KitKat Jan 20, 2021
    rhyd1am , via OnePlus Community App , Jan 20, 2021 :
    What were you expecting? It's an open beta. That's what betas are 🤷‍♂️
    McJader likes this.
  10. srini0301
    Always-On-Display feature is under internal test and will be released in subsequent versions .
  11. Tinglish
    I have the 8t so I'm used to the layout,I personally quite like it,it's not really a massive change like people make out,it just seems cleaner if you know what mean
    SiddharthRaj likes this.
  12. ngshah
  13. rhyd1am likes this.
  14. Sridharan_Sivaraman_S , via OnePlus 7 Pro , Jan 20, 2021 :
    Noticed 2 issues so far.. mobile data not working Jio india even after resetting the APN settings.
    Canvas is not working. It kind of crashes.
    when connected to bluetooth headset suddenly the audio goes off although the song is still being played. said:
    also play/ pause from the notification area is very laggy
    also there is dedicated shortcut for Poweramp from the quick settings 1611165285781.jpg said:
    anujthakurece likes this.
  15. SiddharthRaj
    Donut Jan 20, 2021
    SiddharthRaj , via OnePlus 7 Pro , Jan 20, 2021 :
    Thanks for your response. Appreciate it.
  16. bayy27
    Eclair Jan 20, 2021
  17. Insane_Butcher
    Honeycomb Jan 20, 2021
    Insane_Butcher , via OnePlus 7 Pro , Jan 20, 2021 :
    Let's see what you tell in 1 or 2 days when you eventually find some super irritating bugs. Everyone utilize their smartphones differently, so one group of people won't find certain bugs because they will not be using some functions, the other group may find too many bugs, because the way they use their devices is different. The problem here is that the second group - most likely complain that update is not stable enough and rollback to stable without reporting identified bugs directly to developers. We will see 🙈
    karna11 and McJader like this.
  18. Tinglish
    Your welcome, I'll be honest it looks pretty awesome on my op 7 pro,just a couple of things missing is all
