435
OxygenOS 11 Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. Sourav._.Pradhan
    Gingerbread Feb 3, 2021
    njb7 likes this.
  2. njb7
    Eclair Feb 3, 2021
    njb7 , via OnePlus 7 , Feb 3, 2021 :
    Is it my device's problem?
    Should i revert to stable?
    Or over usage of phone increase ram usage??
  3. Sourav._.Pradhan
    Sourav._.Pradhan , via OnePlus 7 Pro , Feb 3, 2021 :
    I don't see it as a problem, cause it depends on your usage, and ofcourse device will use ram to meet ur usage, and that's why u have 6 gb ram variant, so why you want to save ram?? Then what is the point of buying phone with 6gb ram and then trying to save ram.If u don't want to ur phone to use that much ram then buy phone wuth 2 gb ram, then It will only use 2gb of ram😂 So chill, nothing is wrong here and if u think so then try factory resetting your phone, or wait till next update
    njb7 likes this.
  4. njb7
    Eclair Feb 3, 2021
    It is okay to use too much ram if it increased it's performance(gaming) but performance has dropped much while gaming. While normal usage. Its okay .
    thanks for your reply btw
  5. Sourav._.Pradhan
    Factory reset.
    njb7 likes this.
  6. P1558982547756
    Cupcake Feb 3, 2021
    WillieVerhoeven and SajanKohli like this.
  7. G_Aaraiz_Saeed_Tzrx
  8. Drewbs
    Cupcake Feb 3, 2021
    Drewbs , Feb 3, 2021 :
    I followed this process through, but I don't have the gear icon in the top right of my System Update screen. Does you have another path to use a local update? I'd appreciate any help that could be provided. Definitely want to start using OS11 on my OnePlus 7 Pro!
  9. SajanKohli
  10. G1577228041994
    Cupcake Feb 3, 2021
  11. O1612396645240
    Donut Feb 4, 2021
    O1612396645240 , Feb 4, 2021 :
    Read the first post on this thread carefully.. if you depend on a rock solid experience or are not willing to reset your phone in case you should rather refrain from flashing it and wait for the stable release.
    G1577228041994 likes this.
  12. O1612396645240
    Donut Feb 4, 2021
  13. O1612396645240
    Donut Feb 4, 2021
    The CPU heating up a lot has been reported by other users as well. To help the devs in finding the problem you could provide feedback through the community app. Increased RAM usage is something that you shouldn't be worried about. It's actually a good thing if your phone utilizes the resources it has.
  14. kramik
    Gingerbread Feb 4, 2021
    kramik , Feb 4, 2021 :
    Mine also works and even better than on the Ob19 A10, and with bubbles
    Luarpc likes this.
  15. bayy27
    Eclair Feb 4, 2021
    the_reckoner likes this.
  16. W1587097952078
    Cupcake Feb 4, 2021
  17. DrBrahmesh
    Froyo Feb 4, 2021
    DrBrahmesh , via OnePlus 7 Pro , Feb 4, 2021 :
    After updating to OS 11 OBT I found several issues with my OP7PRO. Videos are not playable after recording in 4k 60fps. Gallery is laggy. Today I find that without connecting to the wrap charger, my device is showing that it is charging in the notification bar with a notification sound ( infact battery discharging).
  18. akks
    KitKat Feb 4, 2021
    akks , Feb 4, 2021 :
    Gallery- Known issue
  19. O1612396645240
    Donut Feb 4, 2021
    Had the same with charging. According to AccuBattery I charged -2% in 7h, not exactly sure why. I replugged it and it would charge just normal.
