435
OxygenOS 11 Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. JATINRATHOUR
    Cupcake Mar 2, 2021
    JATINRATHOUR , Mar 2, 2021 :
    My OnePlus 7T has downgraded to DRM Widevine L3 and not going back to L1. This happened after I upgraded to android 11 beta. Did a stock re flash with MSM and still no luck. Stuck on Widevine L3. Please Help!!!!!
  2. Namitrajsingh
    Cupcake Mar 2, 2021
    Namitrajsingh , Mar 2, 2021 :
    Hi,
    i just intsalled Oxygen os 11 beta 2 from the One plus site.
    after installation during restating showing Boot reason
    now my phone showing only boot reason.
    can anyone help me on this ASAP ?
  3. Namitrajsingh
    Cupcake Mar 2, 2021
    Hi,
  4. Artemus.
    Community Hero 2020 Mar 2, 2021
    Artemus. , Mar 2, 2021 :
    This has been reported countless times. You must perform a factory reset to fix it.
  5. edif2008
    Gingerbread Mar 3, 2021
    edif2008 , Mar 3, 2021 :
    Heey there.
    Sorry to bother. Just experienced a similar issue with Beta 2 from OnePlus Website. I get the `Boot reason` error.
    I did perform a factory reset (data and cache), but it's still stuck with the boot.
    Is there any known way to try and fix this?
    Thanks a lot for the help. Really appreciate it ^-^
  6. X1576870938276
    Cupcake Mar 3, 2021
  7. Namitrajsingh
    Cupcake Mar 3, 2021
    Namitrajsingh , via OnePlus 7 , Mar 3, 2021 :
    Click on system data wipe. You will loos your data.
  8. Namitrajsingh
    Cupcake Mar 3, 2021
    I lost my data but no problem I have backup. I installed open beta 2 yesterday, I think some features are missing, not showing one plus laboratory, no cloud options in OnePlus gallery, always on display also missing.
    And when I get update for open beta 3 ?
    Please help me out of this
  9. Artemus.
    Community Hero 2020 Mar 3, 2021
    Artemus. , Mar 3, 2021 :
    Beta 3 hasn't been released for OP7 yet.
  10. Namitrajsingh
    Cupcake Mar 3, 2021
  11. Artemus.
    Community Hero 2020 Mar 4, 2021
    Artemus. , Mar 4, 2021 :
    Most of that was listed (and reported) in the B2 thread. Maybe check there.
  12. Namitrajsingh
    Cupcake Mar 4, 2021
    Namitrajsingh , via OnePlus 7 , Mar 4, 2021 :
    How can i check ? In which option?
    If you Can tell me in simple way it would be a great help of me,
    Not showing also update log, change log
  13. Artemus.
    Keyword "thread", as in the forum thread corresponding with Beta 2.
  14. Ethan _jenko
    Cupcake Mar 4, 2021
    Ethan _jenko , Mar 4, 2021 :
    Unfortunately, upon installing this beta it has put my OnePlus 7 Pro into a constant boot loop. I have no idea how to get it restored back to normal operation. If anyone has any tips or knows how to fix this I would be greatly appreciative.
  15. Artemus.
    Two words: "factory reset". Hopefully you kept a backup!
  16. aldamy
    Cupcake Mar 13, 2021
  17. Artemus.
    Community Hero 2020 Mar 13, 2021
    Artemus. , Mar 13, 2021 :
    Beta 1 came before 10.3.8.
    I1567901190605 likes this.
  18. aldamy
  19. Artemus.
    Beta 3.
  20. aningro
    Cupcake Mar 15, 2021
    aningro , Mar 15, 2021 :
    To return to Android 10 MP from beta3 do I have to download the file in this message? because it says "Want to go back to Android 10 OBT?" ........... OBT ??????
    sorry but i'm new to OnePlus and i wouldn't want to lock my phone
