437
OxygenOS 11 Open Beta 1 for the OnePlus 7 and OnePlus 7 Pro
  1. akks
    KitKat Jan 21, 2021
    akks , Jan 21, 2021 :
    Send feedback as mentioned in OP
  2. FabioRonzoni
    Donut Jan 21, 2021
    FabioRonzoni , via OnePlus 7 , Jan 21, 2021 :
    This Is the article saying you'll gwt It today
    Bottom in the article there's the link for op7 pro
  3. Joemtz70
    Froyo Jan 21, 2021
  4. akks
    KitKat Jan 21, 2021
    Try in a web browser
  5. Opticon
    Donut Jan 21, 2021
    Opticon , via OnePlus 7 Pro , Jan 21, 2021 :
    I cannot receive calls correctly since the update. It rings, I answer it, but it is silence. The caller says it just went to voicemail. When I call back, the phone will randomly go into speaker mode and I cannot adjust the volume. Clicking the speaker button twice will make it return to normal.
    Everything else about the update seems okay so far, though.
  6. Dinesh1616
    Cupcake Jan 21, 2021
  7. Joemtz70
    Froyo Jan 21, 2021
  8. genialsandeep
    Honeycomb Jan 21, 2021
    genialsandeep , via OnePlus 7 , Jan 21, 2021 :
    I just noticed that hepatic feedback doesn't work in battery saver mode.
    If it turned off...it really vibrating very hard if it was already set to strong vibrating mode.
  9. Fuschy
    Gingerbread Jan 21, 2021
    Fuschy , Jan 21, 2021 :
    So I have installed this over the last Open Beta that was released. Works fine so far. Only "problem" I have is that when I turn on my WiFi it takes a good 2-3 minutes until it actually works and is connected. Sometimes it just doenst even connect to the WiFi...
    Edit: I also lose my mobile connection from time to time for a few sec
    Edit 2: I changed my router from WPA2 to WPA3 (wanted to do that longer but always forgot) Now It seems to be working just fine. Not sure if its a coincidence or not.
  10. N1560510947069
  11. Armin2208
    Eclair Jan 21, 2021
    Armin2208 , Jan 21, 2021 :
    You're right! Because of the dependence to have the OnePlus Community App installed on my phone, I can't give Feedback without having the Beta installed. Or?
    I know it sounds strange. But I know that Google Feed is not included and I would like to have it in the stable build, just like my friend and many other users.
  12. Insane_Butcher
    Insane_Butcher , via OnePlus 7 Pro , Jan 21, 2021 :
    More of a suggestion that has to be posted in appropriate thread or via Reporting tool
  13. VIJAY8544KV
  14. alex_suschin
    alex_suschin , Jan 21, 2021 :
    how to install beta version on oneplus 7 pro T-Mobile version, i have unlocked bootloader and euro firmware, help guys !!!!!
  15. Shrivats_Plus
    Eclair Jan 21, 2021
    Shrivats_Plus , via OnePlus 7 Pro , Jan 21, 2021 :
    OnePlus 7Pro users. Quick question.
    If I am already on open beta will I get this OS 11 open Beta as OTA update or do I need to do it via local upgrade.
    All other previous open Beta updates came OTA automatically. I had this question because the original post here only mentioned local upgrade... However I saw many people posted they received OTA.
    I thought If getting an OTA very soon I will wait for it or else download and install.
    Really appreciate your inputs. Thanks!
  16. Abdul_Aziz544
    Froyo Jan 21, 2021
    Abdul_Aziz544 , via OnePlus 7 , Jan 21, 2021 :
    In my case bubble is working fine in telegram!
  17. vriesdejoop
    Ice Cream Sandwich Jan 21, 2021
    vriesdejoop , Jan 21, 2021 :
    What part of the OP do you not understand? READ!
    Please note:
    1. This Build is only for OnePlus 7/7Pro unlocked Non Carrier variants, and please make sure the battery level is above 30% and a minimum of 3GB of available storage space.
    2. This OBT Build c......
    JNiemi and P1559915943848 like this.
  18. P1611197098717
    P1611197098717 , via OnePlus 7 Pro , Jan 21, 2021 :
    Yup, I can't receive calls sometimes and when i do no one can hear me or my phone wont connect the call. The screen freezes on the connected call and shows a timer set to zero. For now I'm lucky enough i can switch to hangouts since i have fi, but hopefully this gets fixed before the final build.
  19. YaBoiJG
    YaBoiJG , via OnePlus 7 Pro , Jan 21, 2021 :
    I have the T-Mobile version also, installed it last night. It's working great for me so far!
